Author Topic: Con Rod Bolts  (Read 3495 times)
October 12, 2007, 08:02:53 pm
TPW
  • 113
Con Rod Bolts
« on: October 12, 2007, 08:02:53 pm »
Has anyone ever tried reusing con rod nuts and bolts when rebuilding a diesel?  If you do have to used new ones, who sells them?
Reply #1October 12, 2007, 08:49:41 pm
rallydiesel
  • 1880
Con Rod Bolts
« Reply #1 on: October 12, 2007, 08:49:41 pm »
I got mine from the VW dealer. I have heard of lots of people reusing them without problems but they are stretch bolts so you have been warned.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 12, 2007, 08:52:32 pm
TPW
  • 113
Con Rod Bolts
« Reply #2 on: October 12, 2007, 08:52:32 pm »
Did they torque the used ones to 22ft lbs plus 1/4 turn?
Reply #3October 13, 2007, 07:53:09 am
Con Rod Bolts
« Reply #3 on: October 13, 2007, 07:53:09 am »
They're cheap, why the hell take a chance on ruining your engine? Do it right or don't do it at all!
Reply #4October 15, 2007, 06:57:38 am
TPW
  • 113
Con Rod Bolts
« Reply #4 on: October 15, 2007, 06:57:38 am »
The VW dealer shows two different bolts, how do I know which one? One is pressed in, the other is pressed in with a "torque angle method".
Reply #5October 15, 2007, 08:47:41 am
subsonic
  • 1836
Con Rod Bolts
« Reply #5 on: October 15, 2007, 08:47:41 am »
1.6 or 1.9 ?
Reply #6October 15, 2007, 09:02:51 am
TPW
  • 113
Con Rod Bolts
« Reply #6 on: October 15, 2007, 09:02:51 am »
I have a 5 cylinder Audi Turbo diesel that should have the same pistons as a 1.6 VW turbo diesel.
Reply #7October 15, 2007, 11:56:54 am
Con Rod Bolts
« Reply #7 on: October 15, 2007, 11:56:54 am »
How about for the 1.6td while we're at it?
I started looking for some this morning to no avail.
Reply #8October 15, 2007, 01:03:49 pm
subsonic
  • 1836
Con Rod Bolts
« Reply #8 on: October 15, 2007, 01:03:49 pm »
You can check out this link for some detailed discussion on the bolts.
http://vwdiesel.net/phpBB/viewtopic.php?t=4208&postdays=0&postorder=asc&start=0
or you can go to the FAQ section and look at the post for the part numbers.
"ARP Part Numbers"
Reply #9October 15, 2007, 01:24:18 pm
Con Rod Bolts
« Reply #9 on: October 15, 2007, 01:24:18 pm »
Quote from: "subsonic"
"ARP Part Numbers"
Thanks but I'm not wanting ARP Bolts, Already have that #.
I've read through that thread numerous times and I suppose it's possible I missed it but I didn't see anything in there about stock rod bolts.
If you do the math, OE Rod bolts are what $4. ea approx?
So your out a whole $32.00 for OE bolts that last for 400K + on a stock engine. There are guys running stock everything over 100hp.
ARP's are over $100.00.
I'm sticking with OE Bolts, ARP's for the head but Rod's are getting OE Bolts.
Reply #10October 15, 2007, 01:33:43 pm
TPW
  • 113
Con Rod Bolts
« Reply #10 on: October 15, 2007, 01:33:43 pm »
I did order the "torque angle install" bolts, but my Bentley for the Audi Turbo Diesel reads that I should touque to 21 ft-lbs, then 1/2 turn 180 degrees.  Doesn't this seem like a little much?
Reply #11October 15, 2007, 01:47:46 pm
Con Rod Bolts
« Reply #11 on: October 15, 2007, 01:47:46 pm »
Quote from: "TPW"
not for stretch bolts...
Reply #12October 15, 2007, 01:47:46 pm
Con Rod Bolts
« Reply #12 on: October 15, 2007, 01:47:46 pm »
Quote from: "TPW"
Hmm, hard to say. I cant remember right at the moment what the specs are on teh 1.6TD. Guess I had better take the plactic off the Bently when i get home and take a looksee.
