#15
by
blkboostedtruck
on 15 Oct, 2007 14:04
where did you find the EGT gage? I like that one! how much is that one?
thanks Duane
#16
by
giulianot
on 15 Oct, 2007 14:43
The EGT gauge is a glow shift and it was $115 cn and it was on ebay. It reacts to heat very quickly and looks cool, so i went with it.
#17
by
giulianot
on 17 Oct, 2007 09:54
Does anyone know where i can by a new rad fan shroud for the mk1's? mine is so rotted that its beyond sandblasting and paint
#18
by
giulianot
on 22 Oct, 2007 10:30
I made some progress on the cabby biuld. I painted the rad fan shroud, put a new rad in , new overflow bottle, new coolant hoses, and installed the battery. heres some pics
#19
by
blkboostedtruck
on 22 Oct, 2007 20:04
I have some good fan shrouds! where exactly are you located?
thanks Duane
#20
by
giulianot
on 24 Oct, 2007 08:09
Thanks anyways but i got one in for now
#21
by
tSoG-84bit
on 25 Oct, 2007 20:36
Does the AAZ mate up to a mk1 clutch and tranny? I need a new engine, figured I might as well go all out, but plan on staying all mechanical (no tdi)
I've tried searching, and your swap is definitely the closest I can find to what I am looking for.
Any Info you are willing to share on this swap is greatly appreciated.
Thanks,
tSoG.
#22
by
spencebm
on 25 Oct, 2007 23:50
my older bro is putting a 1.8 16v in his cabby...
i wish i had a real bro...
#23
by
giulianot
on 26 Oct, 2007 09:22
Thanks,
tSoG.
Yes the aaz engine will mate to many different clutch combinations it all depend on what trany you will be running, is it an 020, does it have a big spine or a small spline, do you have a 210mm flywheel? my setup is an old 020 trany small spline so i went with a 87 rocco 16v gasser clutch and flywheel and that seems to be holding for now .well see what happens when the motor get broken in and i start to push high levels of boost.
#24
by
giulianot
on 26 Oct, 2007 09:23
my older bro is putting a 1.8 16v in his cabby... i wish i had a real bro...
Convince him that hes making a big mistake going with a garbage gasser, or wait till hes done the swap, then smoke him in your diesel!
#25
by
giulianot
on 26 Oct, 2007 09:28
#26
by
spencebm
on 26 Oct, 2007 11:52
haha, yeah it will happen, this thing is going to be a monster! what kind of tranny are you running? make sure and get a tall 5th gear and go really fast!
#27
by
giulianot
on 26 Oct, 2007 11:58
Thanks, i cant wait to see how fast this car is really going to be. The trany is an ACN with a very tall .69 fifth gear in it, im guesing 240kph @ 4500rpm
#28
by
935racer
on 29 Oct, 2007 16:08
Just finished welding up this custom unit for you this morning:
#29
by
on 29 Oct, 2007 17:25
