I had the Jetta TD (87) towed to a vw shop this morning so I could get the timing properly done. As it turns out, the pump cannot be timed. The dial gauge reads nothing, zero, niet, nada. This shop has a pretty good reputation and with the amount of VW diesels in quebec, I have no doubt they know how they work.
Here's a short resume of what work I did on the engine. I replaced the head, injectors (mercedes, known to be good) and heatshields, new glowplugs, new lifters and used a 1.9TD headgasket. Replaced the crank, intermediate shaft and cam seal, new timing belt and tensionner, aluminum thermostat housing and non-tracked IS pulley were used. There's a bit more but you get the idea.
I got the engine running yesterday. It smoked badly, had little power and the injectors were loud as hell (big rig loud). After three to four minutes, the engine shut off and never started again. I replaced the head because one of the injector boss was cracked. The HG was due for along with the TB. Prior to all this, the engine had started to develop a loud injector knocking. This was the breaking point for me and decided to get dirty. The only thing the engine does is crank and crank and crank. Sometimes it starts for one or two seconds but dies immediatley even when giving it gas. My guess is that fuel accumulates in the cylinder and ignites briefly.
Now the car is sitting docks, with an injection pump that can't be timed. Any ideas as to why the IP can't be timed?
Here are some pics of the car, just for kicks.
Who can tell me what the sensor located on the crankcase vent tube near the intake tube is for?
