Diesel Tach
by
type2 idi
on 19 Nov, 2004 17:21
I'm putting a 1,9l IDI in my 77 westfalia, I know that the send for the tach is the w on the alternator, can i use any aftermarket tach? :?
#1
by
VWRacer
on 20 Nov, 2004 08:26
I searched eBay for "vw diesel alternator" and found
this one[/u].
Or search your local salvage yard. :wink:
#2
by
addautomotive
on 25 Nov, 2004 09:48
You say that so casually! Details please! are you using a kennedy adapter, or a vanagon diesel bellhousing? I was going to do something like this, but the deal fell through on the van.
#3
by
type2 idi
on 29 Nov, 2004 14:26
No I'm not using either, I have a Adapter plate like Kennedy that I sell, It's made of Billet Aluminum rather that cast iron, much stronger!!!
If you what more info let me know I can maybe post pictures here :wink:
#4
by
addautomotive
on 30 Nov, 2004 07:32
Yoiks! More info please, and PICS!
What flywheel do you use, or do you use one from a VW fox, vanagon diesel etc...
what do you charge for the adapter plate?
#5
by
fspGTD
on 30 Nov, 2004 10:22
I searched eBay for "vw diesel alternator" and found this one[/u].
You can't just use any ol' VW diesel alternator to find the "W" terminal... it's got to be off of one that originally had either a factory tachometer or an upshift light. (I think they started putting in the upshift lights in '83 or '84... I know that '84s have the upshift light and therefore the "W" terminal on the alternator.)
#6
by
type53b_gtd
on 30 Nov, 2004 11:28
The dynamic (ie. twin sensor) oil pressure warning system arrived at the same time as the upshift light, and also takes input from the W terminal. After the upshift light was abandoned (around 88 MY in North America for most cars) the oil pressure warning system continued to rquire W terminal input.
I seem to recall the dynamic oil pressure warning system was introduced in late 82 on Jettas, but was certainly there by '83.
Drew
#7
by
fspGTD
on 30 Nov, 2004 12:40
The dynamic (ie. twin sensor) oil pressure warning system arrived at the same time as the upshift light, and also takes input from the W terminal..
Yes, very true!
#8
by
vwmike
on 30 Nov, 2004 12:56
I seem to recall seeing something about a page telling how to build your own circuit to work with like a GTI tach....of course this was before I had a diesel so I didn't care. Can anyone point me in that direction?
#9
by
fspGTD
on 30 Nov, 2004 13:03
http://home.comcast.net/~vwgtd/vwdslfaq.txtissues with this mod: Resistor values may need to be tweaked a little bit. It also doens't work well at high RPMs - acceptable for a street driven / daily driver type turbo diesel with stock governor settings, but probably not for performance modded governor. If we could figure out a better way to modify this circuit to work at high RPMs off the W-terminal, it would be a nice addition.
#10
by
vwmike
on 30 Nov, 2004 15:55
Thanks... I think i already have everything needed
#11
by
Rat407
on 30 Nov, 2004 18:34
So if I unplug the w terminal connector i will not have to listen to my oil warning/buzzer anymore? Cool Beans, Also what model VW did the diesel tach come in? I take it they were rare?
#12
by
Piper106
on 30 Nov, 2004 19:11
Dakota Digital makes their DSL-2 system ($110.95 per their web site
www.dakotadigital.com) that has a sensor that looks at the teeth on the flywheel ring gear. You set the dip switches on the box to tell the system how many teeth on the gear and it gives you "a standard 4 cylinder tachometer signal". Plug and play.
Piper106
#13
by
RAMMSTEIN
on 01 Dec, 2004 15:00
Piper106, your link ain't working mate.
#14
by
Piper106
on 04 Dec, 2004 06:12
