Author Topic: Diesel Tach  (Read 15459 times)
Reply #15December 04, 2004, 11:39:29 am
type2 idi
  • 10
Diesel Tach
« Reply #15 on: December 04, 2004, 11:39:29 am »
Here's some pictures of my adapter with a 200mm flywheel from a beetle with a water-cooled's bolt pattern heart.
<img src="http://img.photobucket.com/albums/v508/Type2/100_4182.jpg">
<img src="http://img.photobucket.com/albums/v508/Type2/100_4181.jpg">
Yann
A-Bus-With-No-Name 77
A-Bus-with-no-name 77
Fox 88
Reply #16December 04, 2004, 11:40:48 am
type2 idi
  • 10
Diesel Tach
« Reply #16 on: December 04, 2004, 11:40:48 am »
Oupps!
Fox 88
Reply #17December 04, 2004, 03:33:27 pm
addautomotive
Diesel Tach
« Reply #17 on: December 04, 2004, 03:33:27 pm »
Hey type2 idi,
I've sent you a Private Message for more info on your adapter plate.
A couple questions:
1) you say you use a "200mm flywheel from a beetle with a water-cooled's bolt pattern heart." Where did you get this? Did you machine it yourself?
2) What starter do you use?
Reply #18December 04, 2004, 06:59:10 pm
type2 idi
  • 10
Diesel Tach
« Reply #18 on: December 04, 2004, 06:59:10 pm »
:oops:  Thanks for little lesson S., for the flywheel I get the heart done at a machine shop then they weld to the flywhell and its off to the balancing. For the stater when I use a gas engine I stay with the starter from the Bus but in this case I use the starter from the engine (Jetta 97) I just have to modify the Bus bell housing a little!
Fox 88
