Author Topic: Looking for place to buy ARP studs/bolts....  (Read 3772 times)
January 05, 2007, 09:14:13 pm
Barry W
« on: January 05, 2007, 09:14:13 pm »
Looking for a company that stocks the ARP bolts or equivalent. I am rebuilding a 1.6L turbo and looking for cylinder head bolts, and possibly con rod bolts.
Also need to know if the 1.8 8V gas stud kits are the same as the 1.6 turbo diesel?
Thanks!
Reply #1January 05, 2007, 09:32:21 pm
Reply #2January 05, 2007, 10:39:49 pm
Barry W
« Reply #2 on: January 05, 2007, 10:39:49 pm »
That looks promising. Thanks!
Reply #3January 05, 2007, 11:27:49 pm
hillfolk'r
  • 1532
« Reply #3 on: January 05, 2007, 11:27:49 pm »
all the older 8v's should use the same studs(gas or diesel),as long as they are both 12mm to begin with
Throttle cables ftw
Reply #4January 06, 2007, 12:38:47 am
Audi80
« Reply #4 on: January 06, 2007, 12:38:47 am »
I bought my studs from Summit Gas engines use 11mm bolts, those won´t fit.
Reply #5January 06, 2007, 12:48:42 am
Barry W
« Reply #5 on: January 06, 2007, 12:48:42 am »
what other stretch bolts need replacing on a rebuild?
Reply #6January 06, 2007, 12:52:42 am
vwmike
  • Authorized Vendor
  • 1158
« Reply #6 on: January 06, 2007, 12:52:42 am »
The rod bolts and the head bolts are your biggest concerns.
Reply #7January 06, 2007, 01:39:21 pm
Barry W
« Reply #7 on: January 06, 2007, 01:39:21 pm »
Thanks.
Reply #8January 09, 2007, 01:03:00 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #8 on: January 09, 2007, 01:03:00 am »
Are these ARP bolts also Strech bolts? Or can I re use them?
Does anybody knows whichs Rod bolt set I have to get from ARP? It's for a 1.9TD (AAZ) engineblock.
Reply #9January 09, 2007, 01:58:15 am
Audi80
« Reply #9 on: January 09, 2007, 01:58:15 am »
You can reuse them.
Reply #10January 09, 2007, 02:27:41 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #10 on: January 09, 2007, 02:27:41 am »
That's better!
Reply #11January 10, 2007, 12:09:31 am
  • 2926
studs
« Reply #11 on: January 10, 2007, 12:09:31 am »
 Will the 11mm gasser studs fit the 11mm early NA diesel block with the 11mm headbolts.
 I've seen the 11mm blocks with 12point, triplesquare, 11mm, gasser streeatch bolts... so I figure the studs will work.
 If so it would be a nice upgrade for the weaker 11mm diesel headbolts that are too short and put large stress on a small area.
