Author Topic: Ecodiesel with new turbo pump- No fuel at injection lines  (Read 33727 times)
Reply #75July 20, 2014, 02:17:33 pm
Diesel_Zuk
  • 182
Re: Ecodiesel with new turbo pump- No fuel at injection lines
« Reply #75 on: July 20, 2014, 02:17:33 pm »
Did as far as I could. Won't start.
Reply #76July 20, 2014, 02:41:12 pm
iamdieselnutmechanic
  • 53
« Reply #76 on: July 20, 2014, 02:41:12 pm »
Damn.  :(
Is the pump still full of fuel? or did it all drain back again?
Hey there, how you doin?
Reply #77July 21, 2014, 04:17:00 pm
  • 2926
« Reply #77 on: July 21, 2014, 04:17:00 pm »
Air in the fuel doesn't usually mean a leak. That '91 filter changes this somewhat.
 It usually means you are pulling a high vacuum and disolved air is expanding so you can see it.
 Is it hard to pull fuel through the filter? Can you suck it through with your mouth?
Reply #78July 21, 2014, 06:07:37 pm
« Reply #78 on: July 21, 2014, 06:07:37 pm »
This is why I run a vac gauge inline on the Veg oil system.  Once I start seeing about 3 lbs or so I know I either need more heat on the tank or I need to think about changing the filter.  Generally the first not the 2 micron second.
Reply #79July 21, 2014, 08:45:12 pm
Diesel_Zuk
  • 182
« Reply #79 on: July 21, 2014, 08:45:12 pm »
It still has fuel, I have it running from a can of diesel currently. I'm extremely pissed this pump is leaking already.
Reply #80July 21, 2014, 09:57:58 pm
Dakotakid
  • 1240
« Reply #80 on: July 21, 2014, 09:57:58 pm »
Listen, seriously, why not do us all a favor and file for your money back. You must be getting very close to your no-chance date....or, maybe it is past. If paypal won't uphold a return, go through your personal credit card company which you have connected to paypal. But, do it......like last week.
At the very beginning of this, I told you (or, tried to tell you) to bypass the Eco return-fuel-loop from pump to filter. It appears you did not do that. At any rate, it appears you got bred on this pump.
I sincerely hope you were keeping a record of any attempt to get hold of the seller.
Make some serious attempt to get your money and get on with your life.
Thanks.
Reply #81July 22, 2014, 01:46:38 am
  • 53
« Reply #81 on: July 22, 2014, 01:46:38 am »
So it runs???  ???
Reply #82July 22, 2014, 02:40:58 pm
Diesel_Zuk
  • 182
« Reply #82 on: July 22, 2014, 02:40:58 pm »
So it runs???  ???
No, I meant the line is coming from a can of diesel. And it's leaking already somehow or other.
Reply #83July 22, 2014, 02:43:01 pm
Diesel_Zuk
  • 182
« Reply #83 on: July 22, 2014, 02:43:01 pm »
Thanks.
I have up to 6 months to file a dispute. And I'm trying to get the car that I love running again. Why are you so mad? I can't get on with my life if I have to think of what pump to put in it next. Also, you don't need to be a about the situation.
Thanks.
« Last Edit: July 22, 2014, 04:23:56 pm by theman53 »
Reply #84July 22, 2014, 04:47:24 pm
Diesel_Zuk
  • 182
« Reply #84 on: July 22, 2014, 04:47:24 pm »
No matter where I have the pump, it still just cranks and cranks, until I pull the cold start lever, than it tries to start, but won't quite. I'm going to check timing again, and set it with a dial as soon as I can.
Reply #85July 22, 2014, 05:38:10 pm
Diesel_Zuk
  • 182
« Reply #85 on: July 22, 2014, 05:38:10 pm »
I'm tempted to try and pull start the car, anything wrong with that?
Reply #86July 22, 2014, 06:42:20 pm
« Reply #86 on: July 22, 2014, 06:42:20 pm »
Some guys do it, I never have. I figger it needs to start on its own daily, so I'd better get it running without the push/pull.
What do you learn if it does run when pushed, but still won't start on its own...? You're back where you started, IMO.
Reply #87July 22, 2014, 07:08:50 pm
Diesel_Zuk
  • 182
« Reply #87 on: July 22, 2014, 07:08:50 pm »
Yeah, that is what I thought too, I just figured if I was able to spin the motor faster than the starter, it might help? Idk.
Reply #88August 08, 2014, 05:47:35 pm
Diesel_Zuk
  • 182
« Reply #88 on: August 08, 2014, 05:47:35 pm »
Set timing with a dial, had a guy that has done several pumps before help me. I am now going to put my old pump back on and see if she'll run. If it does, then I will 100% know it's the pump that is the problem.
Reply #89August 09, 2014, 07:43:19 pm
srgtlord
  • 797
« Reply #89 on: August 09, 2014, 07:43:19 pm »
did you ever do the test to see if its 180 out?
