Author Topic: Ecodiesel with new turbo pump- No fuel at injection lines  (Read 35800 times)
Reply #30June 09, 2014, 04:42:04 pm
Diesel_Zuk
  • 182
Re: Ecodiesel with new turbo pump- No fuel at injection lines
« Reply #30 on: June 09, 2014, 04:42:04 pm »
Still no fuel when I vacuum down the injector return lines. How do I adjust the fuel screw? I know where it is, but I cannot seem to turn it with a flat head screwdriver. Do I have to loosen anything up, or just back the screw in and out?
Reply #31June 09, 2014, 04:44:00 pm
Diesel_Zuk
  • 182
« Reply #31 on: June 09, 2014, 04:44:00 pm »
I'm wondering if the pump is just too worn to build pressure?
It is more likely the full-load screw is out too far.
It might help to post pics or video of the IP.
I am trying to get some up now. Where is the full load screw located?
Reply #32June 09, 2014, 04:45:40 pm
Diesel_Zuk
  • 182
« Reply #32 on: June 09, 2014, 04:45:40 pm »
Reply #33June 09, 2014, 07:49:08 pm
« Reply #33 on: June 09, 2014, 07:49:08 pm »
FAQ...but since you are willing to learn I will help
http://www.vwdiesel.net/forum/index.php?topic=645.0
Reply #34June 10, 2014, 09:15:05 pm
Diesel_Zuk
  • 182
« Reply #34 on: June 10, 2014, 09:15:05 pm »
I tried reading that, and didn't see anything about the full load screw.
Reply #35June 10, 2014, 10:51:01 pm
srgtlord
  • 797
« Reply #35 on: June 10, 2014, 10:51:01 pm »
I still think an electric feed pump would do some good
Reply #36June 11, 2014, 06:21:07 am
« Reply #36 on: June 11, 2014, 06:21:07 am »
and here is the max fuel screw in case someone couldn't find it, and if you are too dumb to find the idle adjust on a 1.6 pump, you should not be doing any of this stuff haha
This pic is in posts 8 and 9 of the linked thread.
Reply #37June 11, 2014, 06:32:41 am
Diesel_Zuk
  • 182
« Reply #37 on: June 11, 2014, 06:32:41 am »
Oh that, yes I did try messing with the fuel screw. I fail to see how adding a feed pump will do me any good, if I'm having no issue with drawing and returning the fuel to the tank.
Reply #38June 11, 2014, 07:17:37 am
« Reply #38 on: June 11, 2014, 07:17:37 am »
What did you mess with when you messed with it?
Reply #39June 11, 2014, 07:37:03 am
Diesel_Zuk
  • 182
« Reply #39 on: June 11, 2014, 07:37:03 am »
I cranked it in a turn, tested it, then a little bit more, little bit more until it was all the way in.
Reply #40June 11, 2014, 04:21:58 pm
Diesel_Zuk
  • 182
« Reply #40 on: June 11, 2014, 04:21:58 pm »
I need to apologize, both for my stupidity, and not listening to you before. I put an electric pump on it, and BAM!!!!!! Fuel at all injectors is good. Just waiting for my buddy with a dial indicator to stop by so I can set the timing, and get this bad girl on the road!!!
Reply #41June 11, 2014, 05:50:17 pm
srgtlord
  • 797
« Reply #41 on: June 11, 2014, 05:50:17 pm »
Told you :)
Reply #42June 11, 2014, 06:03:15 pm
Diesel_Zuk
  • 182
« Reply #42 on: June 11, 2014, 06:03:15 pm »
Told you :)
Lol I know!!! Now I'm trying to get it started. It will only sputter a little bit when I pull the cold start cable. Unfortunately my buddy with the indicator won't be able to come tonight, and I have to work the next three days, so it will be out of commission for a little bit longer still  :(
Reply #43June 11, 2014, 06:38:47 pm
srgtlord
  • 797
« Reply #43 on: June 11, 2014, 06:38:47 pm »
The next thing I would verify is if the pump is 180 degrees out of wack
Reply #44June 11, 2014, 07:20:15 pm
« Reply #44 on: June 11, 2014, 07:20:15 pm »
Told you :)
Great call sir. Glad it is possibly working now.
