Author Topic: Ecodiesel with new turbo pump- No fuel at injection lines  (Read 35801 times)
Reply #90August 09, 2014, 10:26:27 pm
Diesel_Zuk
  • 182
Re: Ecodiesel with new turbo pump- No fuel at injection lines
« Reply #90 on: August 09, 2014, 10:26:27 pm »
Yes, I used an old style pulley. I was correct in saying that it didn't seem to be spitting any fuel out from the delivery valves. With the lines completely off, they barely dripped any fuel whatsoever. I put the old pump back on, didn't try timing it at all, and even with all four injector lines cracked, it almost started. I closed two and it started, closed all four and it purred great. At this point I checked timing and it was damn near spot on, so I called it good.
Reply #91August 09, 2014, 10:27:45 pm
Diesel_Zuk
  • 182
« Reply #91 on: August 09, 2014, 10:27:45 pm »
I have been trying to contact the seller of the pump, 8v-of-fury!, to no avail. I see that he hasn't been online in a while. I need my money back, as I bought this as a ready to go resealed unit. I ended up fixing the leaks on the old pump myself and it hasn't started leaking yet.
Reply #92August 10, 2014, 01:03:57 pm
« Reply #92 on: August 10, 2014, 01:03:57 pm »
Any chance the throttle arm is  off a spline or two?
Reply #93August 10, 2014, 07:31:59 pm
Diesel_Zuk
  • 182
« Reply #93 on: August 10, 2014, 07:31:59 pm »
Tried that. It's not pumping very much fuel, it is barely a drip, not building enough pressure to open the delivery valves.
Reply #94August 31, 2014, 10:12:08 pm
rallydiesel
  • 1880
« Reply #94 on: August 31, 2014, 10:12:08 pm »
You should take the top off the pump and verify that the throttle lever "nub" is actually seated in the piston collar.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #95September 01, 2014, 03:01:31 am
Diesel_Zuk
  • 182
« Reply #95 on: September 01, 2014, 03:01:31 am »
Yes, the problem was that it's not spraying fuel, I'm thinking it's not building enough pressure to pop the delivery valves, because if I loosen them up it will pump, but as soon as I close them, only a very very small amount comes out of the valves.
Reply #96September 01, 2014, 02:47:57 pm
rallydiesel
  • 1880
« Reply #96 on: September 01, 2014, 02:47:57 pm »
If the throttle nub is seated properly in the collar, I would try using a feed pump, removing the entire external throttle arm assembly including the springs and then turn the throttle shaft all the way counterclockwise.
