Author Topic: The occasional bottom end hollow clunk.  (Read 5046 times)
November 28, 2012, 12:21:36 pm
srgtlord
  • 797
« on: November 28, 2012, 12:21:36 pm »
So I never really thought about this until now but, just figured it was just one of those vw noises , but what would cause an occasional bottom end knock on a NA 1.6 that would last anywhere from 15 seconds to 1 minute? Just wondering if there is something else I should look at with the engine out.
Reply #1November 28, 2012, 12:52:33 pm
Re: The occasional bottom end hollow clunk.
« Reply #1 on: November 28, 2012, 12:52:33 pm »
OIL Pump?
Reply #2November 28, 2012, 12:56:03 pm
  • 5104
« Reply #2 on: November 28, 2012, 12:56:03 pm »
When do u hear it?  And what makes u think its bottom end?  Is it just after a cold start?
Reply #3November 28, 2012, 06:32:35 pm
srgtlord
  • 797
« Reply #3 on: November 28, 2012, 06:32:35 pm »
It used to be only after a cold start . It sounded like someone was hitting the oil pan with a hammer.
Reply #4November 28, 2012, 06:44:36 pm
« Reply #4 on: November 28, 2012, 06:44:36 pm »
Tell that someone to knock it off...Or take the hammer away.
Reply #5November 28, 2012, 07:46:39 pm
« Reply #5 on: November 28, 2012, 07:46:39 pm »
Make me chuckle,..   Something then, he meant something not someone.  Or is it the comparative method of association in which he speaks.
Trolls perhaps?  Don't they live under things?
Reply #6November 28, 2012, 08:10:07 pm
  • 5104
« Reply #6 on: November 28, 2012, 08:10:07 pm »
It's probably just normal diesel clatter or ur timing is too advanced when a friend of mine first got his diesel rabbit together he thought the pistons were slamming into the head or something,  this was in the summer, I told him loosen the pump and rotate it away from head a bit and all was well
Reply #7November 29, 2012, 04:23:53 am
srgtlord
  • 797
« Reply #7 on: November 29, 2012, 04:23:53 am »
Damn gremlins
Reply #8November 29, 2012, 04:28:05 am
  • 5104
« Reply #8 on: November 29, 2012, 04:28:05 am »
Damn gremlins
I named all mine Ronnie, Bobby, Ricky, and Mike.
Reply #9November 29, 2012, 04:37:40 am
« Reply #9 on: November 29, 2012, 04:37:40 am »
I would think it would be fuel related. Maybe injector related. Even my TDI will make some bad noise whenever it is cold and cold starting. I think what trev said is accurate as well.
If there is a hammer down there you should take it away, the pans dent eventually.
Reply #10November 29, 2012, 05:11:21 am
srgtlord
  • 797
« Reply #10 on: November 29, 2012, 05:11:21 am »
But the strange thing is the issue would come back after fully warmed up at idle after it reached operating temps.
Reply #11November 29, 2012, 05:52:06 am
« Reply #11 on: November 29, 2012, 05:52:06 am »
How old are the IM shaft bearings?
Reply #12November 29, 2012, 06:06:56 am
srgtlord
  • 797
« Reply #12 on: November 29, 2012, 06:06:56 am »
Lets put it this way, I plan on replacing them. Im just not sure if this will solve this odd issue.
Reply #13November 29, 2012, 11:18:52 am
« Reply #13 on: November 29, 2012, 11:18:52 am »
Damn gremlins
???? Isn't this the season to be hanging and ringing bells????
Put a bell on it.  Then you won't hear the hammer like noise
Reply #14November 29, 2012, 08:03:54 pm
pointynoggin
  • 93
« Reply #14 on: November 29, 2012, 08:03:54 pm »
I got a cherokee that did something like that, 5sec of hammering on start up.  Turned out to be the harmonic balancer.
1991 Jetta 1.6TD, Giles Superpump,
