General Information
General
The occasional bottom end hollow clunk.
Topic: The occasional bottom end hollow clunk. (Read 5165 times)
November 28, 2012, 12:21:36 pm
srgtlord
November 28, 2012, 12:21:36 pm »
So I never really thought about this until now but, just figured it was just one of those vw noises , but what would cause an occasional bottom end knock on a NA 1.6 that would last anywhere from 15 seconds to 1 minute? Just wondering if there is something else I should look at with the engine out.
November 28, 2012, 12:52:33 pm
Moderator
4552
Re: The occasional bottom end hollow clunk.
November 28, 2012, 12:52:33 pm »
OIL Pump?
November 28, 2012, 12:56:03 pm
November 28, 2012, 12:56:03 pm »
When do u hear it? And what makes u think its bottom end? Is it just after a cold start?
November 28, 2012, 06:32:35 pm
srgtlord
November 28, 2012, 06:32:35 pm »
It used to be only after a cold start . It sounded like someone was hitting the oil pan with a hammer.
November 28, 2012, 06:44:36 pm
November 28, 2012, 06:44:36 pm »
Tell that someone to knock it off...Or take the hammer away.
Round 2
November 28, 2012, 07:46:39 pm
Moderator
4552
November 28, 2012, 07:46:39 pm »
Make me chuckle,.. Something then, he meant something not someone. Or is it the comparative method of association in which he speaks.
Trolls perhaps? Don't they live under things?
November 28, 2012, 08:10:07 pm
November 28, 2012, 08:10:07 pm »
It's probably just normal diesel clatter or ur timing is too advanced when a friend of mine first got his diesel rabbit together he thought the pistons were slamming into the head or something, this was in the summer, I told him loosen the pump and rotate it away from head a bit and all was well
November 29, 2012, 04:23:53 am
srgtlord
November 29, 2012, 04:23:53 am »
Damn gremlins
November 29, 2012, 04:28:05 am
November 29, 2012, 04:28:05 am »
Quote from: srgtlord on November 29, 2012, 04:23:53 am
Damn gremlins
I named all mine Ronnie, Bobby, Ricky, and Mike.
November 29, 2012, 04:37:40 am
November 29, 2012, 04:37:40 am »
I would think it would be fuel related. Maybe injector related. Even my TDI will make some bad noise whenever it is cold and cold starting. I think what trev said is accurate as well.
If there is a hammer down there you should take it away, the pans dent eventually.
Round 2
November 29, 2012, 05:11:21 am
srgtlord
November 29, 2012, 05:11:21 am »
But the strange thing is the issue would come back after fully warmed up at idle after it reached operating temps.
Reply #11
November 29, 2012, 05:52:06 am
Reply #11 on:
November 29, 2012, 05:52:06 am »
How old are the IM shaft bearings?
Reply #12
November 29, 2012, 06:06:56 am
srgtlord
Reply #12 on:
November 29, 2012, 06:06:56 am »
Lets put it this way, I plan on replacing them. Im just not sure if this will solve this odd issue.
Reply #13
November 29, 2012, 11:18:52 am
Moderator
4552
Reply #13 on:
November 29, 2012, 11:18:52 am »
Damn gremlins
? Isn't this the season to be hanging and ringing bells?
Put a bell on it. Then you won't hear the hammer like noise
Reply #14
November 29, 2012, 08:03:54 pm
pointynoggin
Reply #14 on:
November 29, 2012, 08:03:54 pm »
I got a cherokee that did something like that, 5sec of hammering on start up. Turned out to be the harmonic balancer.
1991 Jetta 1.6TD, Giles Superpump,
General Information
General
