Head gasket replacement becoming can-o-worms.
by
redscare
on 31 Aug, 2012 20:53
The head gasket went out on my 1.5 D a few months ago. To speed getting the car on the road, I thought a simple gasket swap was in order.
Took off head to find this....
Looks like the damage was done a while ago, as the carbon is built up in the impression and piston.
Why are only the exhaust valves touching and self-clearancing the pistons?
So to add to the non-sense, the 1979 dealer added a/c, which requires the removal to access the bracket to remove the injector pump.
The injector pump partially blocks the a/c bracket from being removed.
Here is why the ip cant come off. Normally the bolt is held on by a bracket and the nut is removed
from the front. All three ip bolts are welded to the support bracket.
So i guess cutting the nut off and installing proper bolt is in order.
How this thing was timed and installed is a mystery.....
EDIT: Side note..... Would the timing belt walk off the ip pulley if the bearing are worn out in the pump? What else would cause the belt to wear out the outside edge?
I could try to realign the pump bracket before completely swapping put the ip pump.
just want to check first. I should probably just start a new thread..
EDIT again: got the pump off, just ground off bottom welded nut and installed proper bolt.
#1
by
on 31 Aug, 2012 21:01
If you've got the head off already, why remove the pump or AC? What else are you planning on doing? Check the valves make sure they aren't ruined and slap it back together? Those are .5 over 1.5 pistons? Never find another set I don't think, virtually unobtainable. I'd have to see the injector pump ac pump relation to judge that scenario. But the injector pump comes off in 5 minutes for me, so it may be the first to go.
The exhaust valves hit because the piston chases them up on the exhaust strokes, they come within a few thousandths every stroke.
#2
by
on 31 Aug, 2012 21:44
Are those water jacket holes plugged with orange junk? what kind of valve clearance was this head running? Perhaps the PO had the order mixed up on the intake and Exhaust?
#3
by
on 01 Sep, 2012 05:04
The exhaust valves all hit because the cam timing was retarded.
#4
by
redscare
on 01 Sep, 2012 09:32
The timing belt was walking off the injector pump pulley and chewing up the belt. I wanted to swap the injector pump for another, as the injector pump shaft feels like it has vertical play when pulling on the pulley. Any other causes for the belt to get chewed up on the outer edge? I almost lost the entire engine as the belt was nearly destroyed before the hg issue.
Also the lower right corner shows the a/c and alt bracket. Will get a better picture now that the head is off.
#5
by
on 01 Sep, 2012 09:37
Those don't look like they were hitting recently,.. and they are too deep to be something that was happening while driving.
Looks like previous owner broke a timing belt.
#6
by
on 01 Sep, 2012 09:48
That doesn't look like dealer installed AC for a 1.5.
If I showed you that welded steel bracket you would laugh, it comes up around the injection pump. Injection pump bolts actually go through it.
Pull the pump, since you are removing that anyway, then you can get to the AC bracket.
No need to remove P-side motor mount,.. except the bushing probably needs replaced while you are that far in there.
#7
by
redscare
on 01 Sep, 2012 10:17
i assumed it was dealer added, but I did see a gasser scirocco with a cobbled together unit with a welded bracket running all over the front of the engine.
Problem is, I cant access the lower bolt holding the ip on the bracket. It is blocked by the bracket holding on the a/c and alt. The bracket holding the a/c and alt has three bolts, the top most one is blocked by the injector pump...so Im at a standstill till I figure it out.
EDIT: the lower bolt is suppose to have a removable nut and the bolt is held on by a gold bracket. My nut is welded to the pump bracket like the other two, so need to get busy with a cut-off wheel. Already have the gold bracket and nut.
#8
by
on 01 Sep, 2012 12:21
your pump bracket is old..
i removed the 3rd lower nut when i had my pump off..
you need a curved wrench, and a grinder.. it can be done!
or else go in from behind with a long extension, and the rear mounting bracket removed.. should get you enough clearance..
if that dont work, its time for the all-mighty u-joint!
#9
by
on 01 Sep, 2012 14:34
a 1/4" wobble extension should get you in there to that lower bolt. Worn IM shaft bushings will cause the belt to wonder, and also cause low oil pressure. As will a bent or mis-installed pump mounting bracket.
#10
by
Toby
on 02 Sep, 2012 22:03
Does the IP have the rear mount in place? From the look of the timing belt you only had minutes before you were in for a new motor. You can't tell much about belt tracking from that chewed up belt. When they start to disintegrate all bets are off as to where they run.
As has been said the piston marks are from running with retarded cam timing for some time. I see that a lot. I wonder if some of the flywheel marks are not off. I had one that would hit the exhaust valves like that if set at the TDC mark. I advanced the cam a bit and all was well. It ran better and was vastly quieter as well.
Also, why do you want to remove the IP? If it is working fine don't Feck with it. (Jason's Rule #12)
ROR is right, the IP/motor mount bracket is an early one. It will also have the small engine mount on the other end. Do yourself a favor and find a later mount bracket that takes the big motor mount and push a new rubber mount into it. Its very easy to do at this point, especially if you are taking off the IP.
#11
by
on 02 Sep, 2012 22:59
Yeah, haven't seen one of those in a long time.
I think I used a 6" extention with my 1/2" swivel socket to get that lower bolt.
#12
by
redscare
on 03 Sep, 2012 18:41
The timing belt issue cropped up after a t-belt change for a squealing tension. I must have put the belt on a hair too tight, as the next belt wore out within 3k(the one pictured above). The second one started to wear on the very outermost edge away from the block. I could literally watch the belt track off the injector pump pulley by about 1-2mm. This would then rub on lip of intermediate shaft and eventually it would hit the timing belt cover if it got too bad and chewed up.
I suspected the ip bearings went south after the first belt change. Car has well over 200,000, probably like 300k since the pistons are .50 already.
I felt a slight vertical movement in the injector pump pulley. But now that Ive been looking for a replacement, I have felt several pumps with axial play like my pump had. So what other issues could cause the timing belt to suddenly start tracking off the pulley besides the ip? Or are all the pumps I looked at bad?
I did test the IM shaft by pulling on the pulley. It has a bit on end play, but I don't exactly have a way to measure it. I see the wear limit is 0.25 mm. Also, my IM pulley has a lip on the edge, I read on here some people removed the lip and had no more belt wear on outside edge.
Any suggestion?
#13
by
redscare
on 06 Sep, 2012 19:59
UPDATE: Head is back on and I installed a used injector pump. After proper timing and adjusting the timing belt, I rotated the engine over a few times to make sure everything was good.
As I did so the timing belt began to walk towards the edge of the ip pulley, but did not go over the edge.
This is the same issue I had pre-head gasket issue.
When looking from the top of the injector pump pulley, the ip pulley appears slightly tilted towards the bracket on the left. When I hold a straight edge across the ip pulley, it misses the camshaft pulley by about .5mm. When holding a straight edge on the camshaft pulley, it misses the edge of the ip pulley by about .5mm.
Timing belt right on edge of ip pulley
Gap between straight edge and pulley.
The injector pump pulley almost appears caulked off to one side, as if the bracket holding the pump is bent towards the passenger side fender
straight edge flat on intermediate shaft, gap at front of ip pulley
straight edge flat on intermediate shaft, gap at back of pulley
If the bracket if bent, I can swap in a replacement from wrecking yard.
If this is the case... how did it get bent? I did the timing belt years ago, no issues. Replaced it due to bad tensioner, started to eat the belt after 3k.
This is a different pump, presenting same issues as before. =(
#14
by
on 06 Sep, 2012 21:39
Where the belt is sitting now isn't bad,.. it hasn't gone over the edge.
To get it to ride closer to teh center; you will need to lift the back of the pump.
This is done by loosening the 2 bolts on the bracket behind the pump, prying the rear up and tightening them back done.
Hard bolts to get to but I have done it with the injection pump still in place.
Sometimes I remove the pump mounting bolts and just move the injection pump aside without removing it the sprocket or belt, to get to the bolts.
