Author Topic: Head gasket replacement becoming can-o-worms.  (Read 7308 times)
Reply #15September 06, 2012, 09:49:26 pm
Re: Head gasket replacement becoming can-o-worms.
« Reply #15 on: September 06, 2012, 09:49:26 pm »
bent pump brackets are NOT impossible.. its quite common actually..
might just need the bracket ADJUSTED even..
Reply #16September 06, 2012, 11:23:46 pm
redscare
  • 15
« Reply #16 on: September 06, 2012, 11:23:46 pm »
I will try to lift the bottom of the pump bracket up a bit tomorrow. hopefully it aligns the belt a bit better.
This is the last thing to do before turbo goes back on and the car finally starts up after a almost a year of collecting dust.  I actually miss driving this thing. and the turbo.   ;)
Reply #17September 07, 2012, 09:00:57 am
« Reply #17 on: September 07, 2012, 09:00:57 am »
Reread fatmobile's post.  It is spot on.  I don't know what you mean by lifting the bottom of the bracket.  You need to lift the end of the bracket that is behind the metal lines or lower the sprocket end.  Basically if looking straight at the pump from the front of the car, you need to rotate it counter-clockwise so that the metal lines are higher relative to the sprocket.
