TURBO TIME!Yesterday, I got my longer set of studs in the mail. I finally got around to putting them in the cylinder head so that I could do the final mounting of the exhaust manifold. Got it and the spacer on and torqued down. Then, finally the time as come for mounting the turbocharger!
Before mounting the turbo, I secured one end of the turbo drain line onto the turbo, with a home-made gasket in between. I got some lapping compound onto the exhaust manifold and tried to lap the turbo to the manifold. I did this because on this turbo setup the turbo does not have a gasket between it and the manifold; it's just the way it was designed. Lapping didn't do much actually, barely even dulled the surface. I guess it won't need it. I cleaned the mating surfaces of lapping compound and torqued the turbo down on the manifold all nice and tight.
Now I moved on to re-doing the turbo oil drain line. Previously I had used all-rubber hose, which would have seeped oil and soaked it up like a sponge. I replaced that with some mylar-inner-lined tubing from the friendly local auto parts store. Got that put onto the line ends and tightened down with clamps.
Tightened the block drain bolt, and the turbo is now officially mounted!
The check list is shortened to 4 things:
-Timing tools
-Installing timing belt
-Modifying and installing turbo oil feed line
-Mounting misc. sensors, brackets, hoses, and mounts.
Can't wait until that is done and it's on to oil leak testing!
