General Information
Troubleshooting
odo, speedo don't work on 2002 tdi auto
Topic: odo, speedo don't work on 2002 tdi auto (Read 4895 times)
August 21, 2011, 08:13:23 am
motomike33y
August 21, 2011, 08:13:23 am »
replaced VSS on transmission but still won't work. Is there any way to test the cluster other than replacement? If I replace the cluster, then apparently I have to get vag-com to reset everything, correct? Any less expensive suggestions? thanks
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress suzuki samurai hardtop that may someday be diesel
2012 golf tdi
August 21, 2011, 10:02:59 am
Re: odo, speedo don't work on 2002 tdi auto
August 21, 2011, 10:02:59 am »
If you have vag-com , you can do an output test to check the speedo operation.
I have experienced more than one mk4 with strange VSS wiring issues. Did you check to see if you have voltage coming to the sensor?
August 21, 2011, 07:21:01 pm
motomike33y
August 21, 2011, 07:21:01 pm »
I don't have a vag-com. didn't do any type of testing, figured easiest and first thing was to replace the vss since I had a new one for it.
2012 golf tdi
August 27, 2011, 02:27:56 pm
catlin_cava
August 27, 2011, 02:27:56 pm »
Do your reverse llights wlrk? This sounds stupid but i had thr same problem on my 2000 and it was the fuse check it, the reverse lights and speedo/odo are on the same fuse
Catlin
2010 VW Golf City 2.0L "Hers"
August 28, 2011, 10:51:58 am
Powered by Spearco
August 28, 2011, 10:51:58 am »
The auto trannies also have a trans speed sensor thats located under the drivers trans mount that can cause simulare issues. The way to access it is to unbolt/remove the trans mount assembly and then you can get to it.
You should at least find someone with VagCom and check outputs and inputs before just throwing sensors at it as they can get spendy.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
August 29, 2011, 05:25:47 am
motomike33y
August 29, 2011, 05:25:47 am »
I changed the sensor under the trans mount, and I think my back-up lights work, but I'll check the fuse. thanks.
2012 golf tdi
August 31, 2011, 10:19:48 am
motomike33y
August 31, 2011, 10:19:48 am »
nope, back-up lights work--guess I save up for vag-com and instrument cluster
2012 golf tdi
September 03, 2011, 04:33:34 am
catlin_cava
September 03, 2011, 04:33:34 am »
I've got a cluster, it's from a 2002 5spees but it will work, pM if your interested
Catlin
September 03, 2011, 07:58:39 am
September 03, 2011, 07:58:39 am »
sadly swapping clusters also issue due to alarm.. will have to be reset via stealership unless you send comp to get it defeated.. comp, key cluster are its 3 main parts..
September 04, 2011, 03:32:14 pm
motomike33y
September 04, 2011, 03:32:14 pm »
thats what I was noticing on some of the threads about the immobilizer, but it seemed that I could reset the key using vag-com, unless I misunderstood(and if I had a vag-com). That also was why I wondered if there is a way to test the current cluster, before trying to replace it. Not making any radical changes until I learn more.
2012 golf tdi
General Information
Troubleshooting
