General Information
General
1985 Diesel Jetta manual tranny question
Pages:
Topic: 1985 Diesel Jetta manual tranny question (Read 9555 times)
Reply #15
September 03, 2010, 07:54:23 am
dyoungen
Re: 1985 Diesel Jetta manual tranny question
Reply #15 on:
September 03, 2010, 07:54:23 am »
I replaced the ball on the relay shaft and the 2 bushings on the top and bottom of the relay shaft. I started the Jetta and had no problem finding all forward gears, 1 thru 5 but no reverse. Could something be out of alignment or?
Forget this question. I put the shift rod bearing where the Relay shaft bushing should have been. I already have ordered the relay shaft bushing.
Last Edit: September 03, 2010, 05:48:12 pm by dyoungen
Reply #16
September 03, 2010, 08:57:46 pm
Dakotakid
Reply #16 on:
September 03, 2010, 08:57:46 pm »
Do you have the little metal tool to align the shifter from inside the car? It is used under the shift boot and clips over the nylon reverse lock-out tab on the left side of the shifter hole.
Did you get an answer on the left-over shifter pieces?
Reply #17
September 06, 2010, 06:19:58 am
dyoungen
Reply #17 on:
September 06, 2010, 06:19:58 am »
No, I don't have the little metal tool to align the shifter. Where can I find one of those?
I think I have figured out the rest of those pieces.
Reply #18
September 06, 2010, 06:40:06 am
Reply #18 on:
September 06, 2010, 06:40:06 am »
wwwgermanautoparts.com sells the tool or you can make one yourself. I think the templates are in the FAQ
Reply #19
September 06, 2010, 04:32:10 pm
dyoungen
Reply #19 on:
September 06, 2010, 04:32:10 pm »
I looked in the FAQ section but didn't see anything about the metal tool to align the shifter.
Reply #20
September 06, 2010, 04:55:47 pm
rallydiesel
Reply #20 on:
September 06, 2010, 04:55:47 pm »
Best way I find is to put the trans in reverse by manually setting the selector on the trans and then putting the gearshift into the reverse position and tightening the pinchnut. No template needed.
1991 Jetta TD - sold
2001 Golf TDI - Son's
Pages:
General Information
General
