1.9td pump on 1.6 NA? Possible?
Topic: 1.9td pump on 1.6 NA? Possible? (Read 1850 times)
August 31, 2009, 01:06:49 pm
spencebm
August 31, 2009, 01:06:49 pm »
I was wondering if you could run a 1.9 pump on a 1.6 motor. Do you need the 1.9 bracket or the 1.6? Which pump gear do you need? Also what about the injector lines and timing belt? Can I time it the same way as the bentley describes? Thanks for the help.
Ben Spencer
September 01, 2009, 09:42:52 am
Re: 1.9td pump on 1.6 NA? Possible?
September 01, 2009, 09:42:52 am »
gotta time it with the right injectors in it to make the bently timing spec any good. n/a injectors are like 130 bar or something, and turbo injectors are 155 bar or something. so there will be artificial advance with the 1.6 injectors and AAZ pump.
September 01, 2009, 01:26:48 pm
smutts
ClackClackClackClackClack
September 01, 2009, 01:26:48 pm »
You had better check that the pulley offsets match, as the later pumps have a meatier bearing at the cambelt pulley end of the pump, (a good thing, as due to wear the pulleys on my 1.6 GTD's flop about like spastic fish
) This might make it a non easy swap.
