#15
by
galaboff
on 14 Mar, 2011 09:33
There's a kit that exists but it's about $4000!
what kind of kit?
turbo? downpipe?
$4000 is too much I think..
#16
by
X@V
on 14 Mar, 2011 10:03
#17
by
rallydiesel
on 14 Mar, 2011 13:41
I would think 2.0 PD would be a great engine for upgrades. 16v is a huge advantage over bottlenecked 8v head. Plus people are more likely to sell them due to the chain issue. Do it!!!!!
#18
by
X@V
on 14 Mar, 2011 14:19
Same problem than the BHW 8v?
Is there any big difference with the internals of the PD140? If the 170 has better pistons and rods, I'll try to find this one.
My other question about the 16V: which injectors could I use? These are probably not the same nozzles than into a PD150!
#19
by
rallydiesel
on 14 Mar, 2011 20:04
Whoops. Got my engines mixed up. No you are right. Only the 8v BHW had the balance shaft issue. Did the BKD just come on Audi A3's?
#20
by
galaboff
on 14 Mar, 2011 23:12
No,
come on Golf , Passat, Touran, Tiguan, Jetta..
..A3, A4, A6, Q5
#21
by
X@V
on 15 Mar, 2011 06:33
The BKD are easy to find...
I would like to know if it's better to choose a 170 instead of 140...
I could use my EDC15P with the 140...
#22
by
galaboff
on 17 Mar, 2011 12:38
If you make serious tuning, better take BKD, easy to find and low cost..
#23
by
X@V
on 17 Mar, 2011 13:02
Good!
About the injectors (almost nozzles), I suppose these aren't same as the ARL??
#24
by
galaboff
on 18 Mar, 2011 14:04
ARL nozzles are bigger than BKD ones.
#25
by
X@V
on 19 Mar, 2011 17:40
The spray pattern is probably not the same.
I have 220 nozzles into my PD150, I suppose they won't work into the BKD injectors...??
As I can see, the PD170 injectors are piezo units instead of solenoides... is it the same thing for BKD / BKP???
#26
by
galaboff
on 21 Mar, 2011 06:23
Your 220 nozzles will fit on BKD injectors...99%
#27
by
X@V
on 21 Mar, 2011 08:15
As I can see, the PD140 nozzles are DSLA152P 1287++, this is not the same spray angle than the DSLA150P 1043 from the PD150/130...
I'll need custom nozzles!!
It seems that the PD140 conn rods are the same as the PD100. I could replace them by a set of PD130/150 rods and I would get a very strong block.
#28
by
galaboff
on 23 Mar, 2011 05:45
#29
by
X@V
on 23 Mar, 2011 09:34
Good!
It sounds good!
