Author Topic: FS: Lightened and balanced AAZ connecting rods  (Read 6426 times)
March 21, 2009, 01:23:09 am
Dr. Diesel
  • Authorized Vendor
  • 1341
« on: March 21, 2009, 01:23:09 am »
sold
Reply #1March 21, 2009, 11:00:51 am
subsonic
  • 1836
« Reply #1 on: March 21, 2009, 11:00:51 am »
Bryson,
Were these balanced with the old bushings/ bearings still in or out?  Did you do the balance?  If so, could you discribe the jig you used?
BTW-Free bumpski and thanks for the info on the mani's.  I am working with him on getting some.
Reply #2March 21, 2009, 03:50:15 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #2 on: March 21, 2009, 03:50:15 pm »
The small end bushings were found still in dimensional specs and left alone.
Balancing isn't typically done with babbit bearings installed, and they weren't in this case. To achieve balance perfection, you can weigh the bearings you buy for these, mix and match, and remove material to make equal weight sets before installing.
I did the balancing, using an apparatus similar to this:
Reply #3March 21, 2009, 08:03:54 pm
jasonsansfleece
  • 162
« Reply #3 on: March 21, 2009, 08:03:54 pm »
Thats interesting. Are you measuring the turning moment around the wrist pin, not the mass. Would a more accurate measurement be equal mass and same center of gravity?
Guy
Reply #4March 21, 2009, 10:16:24 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #4 on: March 21, 2009, 10:16:24 pm »
it is mass and center of gravity. the rod's ends are supported by roller bearings.
this is how they do it, from local shop to NHRA.
Reply #5March 21, 2009, 10:43:37 pm
« Reply #5 on: March 21, 2009, 10:43:37 pm »
very interesting...  how much would you charge to balance some rods, or is it too time consuming and not worth it?
Reply #6March 22, 2009, 03:44:22 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #6 on: March 22, 2009, 03:44:22 pm »
Just balancing, $15 each.
Reply #7March 22, 2009, 04:53:06 pm
« Reply #7 on: March 22, 2009, 04:53:06 pm »
Quote from: "Dr. Diesel"
hmmm i might consider that when installing the girdle  8) thanks
Reply #8April 02, 2009, 06:34:23 am
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #8 on: April 02, 2009, 06:34:23 am »
up
Reply #9April 09, 2009, 12:32:44 pm
saurkraut
  • 904
« Reply #9 on: April 09, 2009, 12:32:44 pm »
How about $100 US no core?  Or would you like the 1.6TD rods back?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #10April 09, 2009, 02:37:41 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #10 on: April 09, 2009, 02:37:41 pm »
hmmmm
