For Sale/Looking For
Parts for Sale/Wanted
FS: Lightened and balanced AAZ connecting rods
Topic: FS: Lightened and balanced AAZ connecting rods (Read 6541 times)
March 21, 2009, 01:23:09 am
Dr. Diesel
Authorized Vendor
March 21, 2009, 01:23:09 am »
sold
March 21, 2009, 11:00:51 am
subsonic
March 21, 2009, 11:00:51 am »
Bryson,
Were these balanced with the old bushings/ bearings still in or out? Did you do the balance? If so, could you discribe the jig you used?
BTW-Free bumpski and thanks for the info on the mani's. I am working with him on getting some.
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
March 21, 2009, 03:50:15 pm
Dr. Diesel
Authorized Vendor
March 21, 2009, 03:50:15 pm »
The small end bushings were found still in dimensional specs and left alone.
Balancing isn't typically done with babbit bearings installed, and they weren't in this case. To achieve balance perfection, you can weigh the bearings you buy for these, mix and match, and remove material to make equal weight sets before installing.
I did the balancing, using an apparatus similar to this:
March 21, 2009, 08:03:54 pm
jasonsansfleece
March 21, 2009, 08:03:54 pm »
Thats interesting. Are you measuring the turning moment around the wrist pin, not the mass. Would a more accurate measurement be equal mass and same center of gravity?
Guy
March 21, 2009, 10:16:24 pm
Dr. Diesel
Authorized Vendor
March 21, 2009, 10:16:24 pm »
it is mass and center of gravity. the rod's ends are supported by roller bearings.
this is how they do it, from local shop to NHRA.
March 21, 2009, 10:43:37 pm
March 21, 2009, 10:43:37 pm »
very interesting... how much would you charge to balance some rods, or is it too time consuming and not worth it?
March 22, 2009, 03:44:22 pm
Dr. Diesel
Authorized Vendor
March 22, 2009, 03:44:22 pm »
Just balancing, $15 each.
March 22, 2009, 04:53:06 pm
March 22, 2009, 04:53:06 pm »
Quote from: "Dr. Diesel"
hmmm i might consider that when installing the girdle
thanks
April 02, 2009, 06:34:23 am
Dr. Diesel
Authorized Vendor
April 02, 2009, 06:34:23 am »
up
April 09, 2009, 12:32:44 pm
saurkraut
April 09, 2009, 12:32:44 pm »
How about $100 US no core? Or would you like the 1.6TD rods back?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
April 09, 2009, 02:37:41 pm
Dr. Diesel
Authorized Vendor
April 09, 2009, 02:37:41 pm »
hmmmm
