Quote from: "arb"OMG !!! 110 ft/lb !!! How close is that to shearing off the bolts / studs ?my raceWEAR stretch i mean 'studs' gave out at approx 90 ft/lbs. :roll: ARP FTW!
Well, it has taken me the last 3 nights here and there to read through this thread, and I finally made it to page 20!!! Now I am setting here awaiting the news to see how it did on your trip to and fro work!!! Keep up the great work and especially the posts with pics! I have learned so much and cannot wait to tear down my 86 Golf Diesel and rebuild it with everything I learned here!
I took it up a nice big hill on my way home...18-19psi... holding strong.. :twisted:I'm trying to keep the boost down under 20psi...... it's hard....boost=
Originally, the MK2 had a sleeve in the bushings. Sometimes, they rust to the inside of the old bushing, and you can't see them.Did you install a new MK2 sleeve on the bushing when you installed the TT bushings?I'm asking because, I have a GLI, and am thinking of rebuilding the a-arms with the TT bushings. I may pass on that idea, if I have to make a custom sleeve for the bolt/bushing.
Dear 53 Willys,nice to see, that you engine runs. I was very scarry, when i read, that you gasket (i get my on the same day) was leaking on the first start up. As i understood you right, everthink is fine now.You have a 1.9 AAZ head or? If yes the compression ratio should be less than stock, how is you engine starts, do you feel a differend at start up or even until it is warm?Best RegardsClemens
Quote from: "88jetta350"Those gauges are great. I may end up using them as well. What color do they light up?the isspros I have light up green.....like stock..
Incredible project, hope i can put that much work into mine !!! Really nice diesel !!! Keep up the good work ! :twisted:
