T3 on AAZ, 2.5" or 3" exhaust?
Topic: T3 on AAZ, 2.5" or 3" exhaust? (Read 2978 times)
June 02, 2008, 01:05:22 pm
Dirtrag2
June 02, 2008, 01:05:22 pm »
hi everyone, I finally got around to stripping my old K03 off my 97 jetta and replacing it with a T3 an' going to have a full exhaust fabbed up. should I go with 2.5" or 3" ? Keep in mind that the whole thing will be done from turbo to the end.
also, on a T3 if I want to run 30 psi boost, do I have to block the wastegate??
seems to me I read something about thes in here :oops:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
June 02, 2008, 07:25:28 pm
Chestrockwell
June 02, 2008, 07:25:28 pm »
I would try to go for 3" exhaust for sure. I have a t3 on my AAZ and I had to weld the wastegate shut to get to 30psi; this is hard on the turbo and makes a lot of heat so I use the max fuel screw to keep the boost down around 25. This turbo had new bearings 30000k ago and oil changes every 6 months and it's loose already.
June 03, 2008, 06:41:57 pm
Dirtrag2
June 03, 2008, 06:41:57 pm »
ok 3" it is :lol:
how do i go about blocking the wastegate? 'cause i would like to run 25+ psi
...Darcy
June 05, 2008, 02:42:48 pm
Dirtrag2
June 05, 2008, 02:42:48 pm »
turbo is going on tonight, if anyone can tell me if i should block the wastegate and if so how it would be apreciated!
...Darcy
June 06, 2008, 04:39:42 am
foxracer1
Authorized Vendor
June 06, 2008, 04:39:42 am »
I would get a manual boost controller. I have mine blocked off and it obviously makes more than 20 it pegs my boost gauge out.
As Chestrockwell said its going to be very hard on your turbo. I also have 3".
I welded the passage between the wastegate port and the exducer of the turbine. Then i just put the plate back on the wastegate. I plan to make a dump pipe for the wastegate and run a MBC.
The turbo really wakes up around 10PSI it shoots up past 20 on my gauge very quick.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
June 08, 2008, 08:23:54 am
Dirtrag2
June 08, 2008, 08:23:54 am »
thanks for the advice... i'll be looking for a boost control system then.
...Darcy
