Author Topic: T3 on AAZ, 2.5" or 3" exhaust?  (Read 3043 times)
June 02, 2008, 01:05:22 pm
Dirtrag2
  • 298
« on: June 02, 2008, 01:05:22 pm »
hi everyone, I finally got around to stripping my old K03 off my 97 jetta and replacing it with a T3 an' going to have a full exhaust fabbed up.  should I go with 2.5" or 3" ? Keep in mind that the whole thing will be done from turbo to the end.
also, on a T3 if I want to run 30 psi boost, do I have to block the wastegate??
seems to me I read something about thes in here  :oops:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #1June 02, 2008, 07:25:28 pm
Chestrockwell
  • 95
« Reply #1 on: June 02, 2008, 07:25:28 pm »
I would try to go for 3" exhaust for sure. I have a t3 on my AAZ and I had to weld the wastegate shut to get to 30psi; this is hard on the turbo and makes a lot of heat so I use the max fuel screw to keep the boost down around 25. This turbo had new bearings 30000k ago and oil changes every 6 months and it's loose already.
Reply #2June 03, 2008, 06:41:57 pm
Dirtrag2
  • 298
« Reply #2 on: June 03, 2008, 06:41:57 pm »
ok 3" it is  :lol:
how do i go about blocking the wastegate? 'cause i would like to run 25+ psi
...Darcy
Reply #3June 05, 2008, 02:42:48 pm
Dirtrag2
  • 298
« Reply #3 on: June 05, 2008, 02:42:48 pm »
turbo is going on tonight, if anyone can tell me if i should block the wastegate and if so how it would be apreciated! :)
...Darcy
Reply #4June 06, 2008, 04:39:42 am
foxracer1
  • Authorized Vendor
  • 991
« Reply #4 on: June 06, 2008, 04:39:42 am »
I would get a manual boost controller. I have mine blocked off and it obviously makes more than 20 it pegs my boost gauge out.
As Chestrockwell said its going to be very hard on your turbo. I also have 3".
I welded the passage between the wastegate port and the exducer of the turbine. Then i just put the plate back on the wastegate. I plan to make a dump pipe for the wastegate and run a MBC.
The turbo really wakes up around 10PSI it shoots up past 20 on my gauge very quick.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #5June 08, 2008, 08:23:54 am
Dirtrag2
  • 298
« Reply #5 on: June 08, 2008, 08:23:54 am »
thanks for the advice... i'll be looking for a boost control system then.
...Darcy
