Author Topic: How do I hook up the tach?  (Read 5193 times)
May 18, 2008, 07:51:37 am
spencebm
  • 686
« on: May 18, 2008, 07:51:37 am »
I have come across a tachometer and need to swap it in my car.  I have done some searching and found little about actually running a wire from the W terminal to the tach in the cluster.  What kind of pick up wire should I run and how does it fit into the cluster?  Any help would be great!  Thanks!
Ben Spencer
Reply #1May 18, 2008, 08:48:58 am
gigaz2
  • 626
« Reply #1 on: May 18, 2008, 08:48:58 am »
any kind of insulated wire, its just a signal, no current.
your tachometer is a diesel one right? aftermarket stuff is 99% gas, and they don't work with W signal.
even so you can always improvise an pickup, optical or Hall effect.
Reply #2May 18, 2008, 12:54:22 pm
  • 3255
    • My collection of HOWTOs
« Reply #2 on: May 18, 2008, 12:54:22 pm »
Here's the chart you need to determine what cluster pin goes to the W terminal:
http://www.xjamiex.com/mk2resource/electrical/CE2cluster.html
And yeah... it needs to be a diesel tach (only goes to 5.5K).  If it goes to 7K it's a gasser tach and won't work directly... lots and lots of data here and at www.vwdieselparts.com on options.
Reply #3May 19, 2008, 06:16:43 am
spencebm
  • 686
« Reply #3 on: May 19, 2008, 06:16:43 am »
thanks for the help
Ben Spencer
