#75
by
giulianot
on 26 Jan, 2008 15:23
So brought the short block to the engine builder today and we took of the pan and we saw this,
as you can tell there is alot of damage and the main cap bolts were not stretch bolts and were torqued to 48 ft-lbs . I really dont know what caused this failure. the engine builder is giving me a full warranty and is purchasing a new short block to rebuild for me. i should have the new short block back in a month or so.
#76
by
giulianot
on 28 Jan, 2008 11:57
The engine builder is buying a used short block from the junkers and boring it out. He also needs to replace two pistons since they are cracked and .5mm over (+.035). I am also going to machine a flat on the used aaz crank to fit a tdi crank sprocket. AAZ crank noses were inherently weak and were changed to a stronger design for the TDI's. As for the cap bolts i just came to a new discovery, there is an engine serial number specific cap bolt to use, prior to AAZ 560 000 you use N 102 638 01 which is a m10x65 bolt, and after AAZ 560 001 you use N 901 300 01 which is a AM10x80 bolt. I wish my engine builder new this before he did my motor
#77
by
935racer
on 28 Jan, 2008 14:34
Geez man you have had quite the troubles. At least your engine builder is manning up and fixing his screw up.
#78
by
giulianot
on 04 Feb, 2008 10:56
YA, this motor has brought me more pain then joy! Since the damage internally was so extensive the engine builder opted to replace everything. He also has a lead on a vw factory rebuild AAZ, which I personally would prefer. In my opinion nobody can rebuild them as well as VW. My question is,did i sheer are the factory cap bolts good enough for 23.5 : 1 compression ratio and an extra 30 psi boost? Are ARP cap bolts necessary in my application?
#79
by
935racer
on 04 Feb, 2008 11:24
I would put ARP's in, I have them on my 1.6, the only mod to my bottom end and I am just shy of 200WHP.
#80
by
stewardc
on 04 Feb, 2008 11:54
ARP all round is a necessity. I put them in my AAZ.
#81
by
giulianot
on 12 Feb, 2008 11:25
Not much progress lately. My engine builder has found a good used short block and is starting the rebuilding process all over again. This time I will be using ARP cap bolts, as they are much stronger. I also have to machine the crank nose to fit a tdi crank pulley. AAZ crank nose were inherently weak and were know to spin on the pulley. While the engine is being built im sourcing a better method of cooling the oil, like a thermostatically controlled front mount oil cooler, rather than the stock oil-to-water heat exchanger. I wanna dissipate that heat into the atmosphere not the coolant. Im ready to upgrade my stock t3 turbo now, its ok but it only makes boost to 23-24 psi reliably so....... im looking into a custom t3/t4 hybrid that can make 30 psi reliably!
#82
by
stewardc
on 12 Feb, 2008 11:55
#83
by
on 12 Feb, 2008 12:52
Hopefully you get a block soon. Look at the volvo 740 turbo cars for an oil cooler. It's bolt on. (I think I got that right)
The heat exchanger also heats the oil to reduce engine wear when the car is cold.
#84
by
giulianot
on 22 Apr, 2008 20:45
#85
by
on 22 Apr, 2008 20:55
Progress
Looking good man. I'll have to come over for a spin once you get it going (again)
#86
by
giulianot
on 01 Jul, 2008 19:37
#87
by
Dr. Diesel
on 03 Jul, 2008 04:15
and then we'll go autocrossing!.... in your car... because mine isn't done. :evil:
#88
by
giulianot
on 03 Jul, 2008 08:10
I cant wait to autocross this car! soon enough!
I got the oil cooler today in the mail and it looks like it will work well. Only one problem, the oil cooler sandwich plate is thinner than my stock oil cooler. So I have to run the shorter style oil filter nipple off a vw without a oil cooler.
and I got my new lower timing belt cover
#89
by
Dr. Diesel
on 03 Jul, 2008 09:49
if your cooler is anything like the volvo sandwich plates, you'll find the no cooler threaded pipe is way too short. You'll probably end up having to remove a half an inch of length from the current cooler-equipped pipe.
