Golf TD more power required - options?
Topic: Golf TD more power required - options? (Read 7740 times)
August 08, 2007, 07:46:45 am
nogama3
August 08, 2007, 07:46:45 am »
so what can i do next to get more power after this:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=9939
i was thinking off maybe a front mounted intercooler, turbo or anything else you guys can advise.
August 08, 2007, 07:48:02 am
zaprzal
August 08, 2007, 07:48:02 am »
do you already have 1.6td boost pin? what turbo do you use?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm
August 08, 2007, 12:27:23 pm
nogama3
August 08, 2007, 12:27:23 pm »
using the original 1.9 pin and i beleive that its a kkk turbo.
August 08, 2007, 12:42:31 pm
bert
August 08, 2007, 12:42:31 pm »
Nogama,come over to halesowen mate,i will take you for a blast in my AAZ TD mk1 golf,no intercooler,and its rapid,i just altered the aneroid pin :wink:
Bert
August 08, 2007, 12:47:26 pm
nogama3
August 08, 2007, 12:47:26 pm »
Bert, I'll have to do that mate...
August 08, 2007, 12:51:55 pm
zaprzal
August 08, 2007, 12:51:55 pm »
change boost pin for 1.6td one and check what turbo do you have kkk k03 or k14
August 09, 2007, 12:53:58 am
nogama3
August 09, 2007, 12:53:58 am »
ok guys, bit of a thick question but where is this pin located and how easy is it to change it over, i take it its from a mk2 golf.
is this pin the same as mentioned by bert and zaprzal?
thanks
August 09, 2007, 01:01:27 am
zaprzal
August 09, 2007, 01:01:27 am »
pin is located here:
August 09, 2007, 03:48:40 am
nogama3
August 09, 2007, 03:48:40 am »
very impressive pics.
next questions:
how do i go about changing this pin?
from which vehicle do i get this pin from?
is it a diy job?
August 09, 2007, 03:53:03 am
zaprzal
August 09, 2007, 03:53:03 am »
yes it is 100% diy
get one from 1.6td or machine yours.
August 09, 2007, 05:20:12 am
nogama3
August 09, 2007, 05:20:12 am »
sorry to be a pain in the *ss, from which part of the engine bay do i remove this part from?
fuel pump or somewhere else?
thanks
Reply #11
August 09, 2007, 05:42:06 am
zaprzal
Reply #11 on:
August 09, 2007, 05:42:06 am »
top of pump
Reply #12
August 09, 2007, 06:09:20 am
Reply #12 on:
August 09, 2007, 06:09:20 am »
Here you are
http://vwdiesel.net/phpBB/viewtopic.php?t=645
What is the green bar represent in this picture?
Reply #13
August 09, 2007, 06:10:55 am
zaprzal
Reply #13 on:
August 09, 2007, 06:10:55 am »
Quote from: "burn_your_money"
I think it's fuel dose
Reply #14
August 09, 2007, 07:05:28 am
con
Reply #14 on:
August 09, 2007, 07:05:28 am »
wow those pictures are really helpful. Ok so before you take the pin out you mark where it is so if you get lost you can return to stock?
Then is it just a case of turning the pin 180 degrees and putting it back?
