Turbo on my NA...
Topic: Turbo on my NA... (Read 4943 times)
July 18, 2007, 04:36:50 pm
hamradio
Turbo on my NA...
July 18, 2007, 04:36:50 pm »
Hi,
I'm getting ready to turbo my 1.6 na. I'm getting the manifolds, and am going to the junkyard to find a turbo. For the downpipe off the turbo (for lack of a better term), what should I use? I thought I read something about some downpipe being able to clear the shift linkage, or something. I also have a bunch of 3" stainless pipe; would it work to just use that as an exhaust for it? How much would the turbo quiet it down?
July 18, 2007, 04:39:47 pm
hamradio
Turbo on my NA...
July 18, 2007, 04:39:47 pm »
Also, I have seen the threads on the vortex and such, with "16vjohn" turboing his rabbit.
July 18, 2007, 08:42:07 pm
bevboyy
Turbo on my NA...
July 18, 2007, 08:42:07 pm »
As I added to that post on 'vortex..
If you are keeping the n/a pump, I would suggest using a K14 or a T2.
If you are getting an actual TD pump, then go T3 or K24.
Make sure that there is no real play in the shaft of the turbo. Be prepared to rebuild it.
You can use the stock downpipe off the manifold. If you have a little more cash, you can send it out to get extrude honed. You can use the stock flange "toilet bowl" downpipe, but I would suggest you take that to a exhaust fabber, and have them make one out of larger diameter piping (eg: 2.25 to 3.00 id) and attach it to the flange (make sure they enlargen the flange opening to match the piping you select).
If you have more cash, then get a Passenger Performance downpipe.
Besides that, just install a glasspack inline to keep the boominess at bay, and the exhaust will not be loud. Yes the turbo does cut down quite a bit of the noise.
You will also need the oil filter mount from a TD and the oil feed line as well. The TD mount has an extra fitting to send oil to the turbo.
You will have to either get a TD oil pan or weld a boss onto the stock oil pan (near the top lip of the pan) for the turbo's oil drain line.
There are some things you should get:
EGT guage <-- highly advisable - helps monitor your EGT levels.
too high EGT is major bad for a n/a motor.
Intercooler <-- highly adviseable - helps lower EGT's
Proper air/oil cooler set up.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
July 18, 2007, 09:34:49 pm
Turbo on my NA...
July 18, 2007, 09:34:49 pm »
Yup and keep in mind that the turbo block and config are a bit different from the NA setup:
- oil squirters in the block to spray oil on the pistons
- oil cooler mounted between the oil filter and filter flange
- different injector nozzles and breaking pressure
So if you're using the normal block you may want to pay particular attention to boost and temperatures.
July 19, 2007, 09:15:53 am
Benjamin
Turbo on my NA...
July 19, 2007, 09:15:53 am »
on a 1.6D? or do you mean a 1.6td?
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
July 19, 2007, 02:17:00 pm
Turbo on my NA...
July 19, 2007, 02:17:00 pm »
i definetly suggest getting a pyrometer
July 19, 2007, 02:43:25 pm
bevboyy
Turbo on my NA...
July 19, 2007, 02:43:25 pm »
Intercooling should be a given when using forced induction. Especially if you're deciding to turbo a plain jane 1.6D!
EGT gauge = pyrometer...another necessity. Don't go boostin' with out it...
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
July 19, 2007, 04:08:57 pm
hamradio
Turbo on my NA...
July 19, 2007, 04:08:57 pm »
How much does a pyrometer cost?
July 19, 2007, 04:22:08 pm
bevboyy
Turbo on my NA...
July 19, 2007, 04:22:08 pm »
I answered your question on 'vortex. Read there. Ebay is your best bet. Do search for EGT gauge.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
July 19, 2007, 07:20:46 pm
Turbo on my NA...
July 19, 2007, 07:20:46 pm »
I got an EGT setup that was never installed for about $130 shipped off vortex. It's a VDO setup
July 19, 2007, 07:22:12 pm
Turbo on my NA...
July 19, 2007, 07:22:12 pm »
pyrometer and intercooler aren't a necessity on a na turned td, unless hes tuning, then its just as much a necessity as it is on a td.
Reply #11
July 19, 2007, 07:46:35 pm
hamradio
Turbo on my NA...
Reply #11 on:
July 19, 2007, 07:46:35 pm »
bevboyy, sorry, I missed that. Thanks.
I'd like to put a pyrometer on it, just to be on the safe side.
Reply #12
July 19, 2007, 09:00:08 pm
bevboyy
Turbo on my NA...
Reply #12 on:
July 19, 2007, 09:00:08 pm »
That would be prudent.
Intercoolers are not that expensive, and since the N/A lacks the oil cooling jets, anything that helps cool the intake charge will be beneficial.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Turbo on my NA...
