Waste Gate Lines
Topic: Waste Gate Lines (Read 3088 times)
July 15, 2007, 07:20:18 am
Riverfurm
Waste Gate Lines
July 15, 2007, 07:20:18 am »
My Garret turbo has two lines coming from it to the waste gate. One is a small line infront of the turbo inlet where the intake boot connects. And a larger line that comes from the top of the turbo on the side that goes to the intake manifold.
Do I disconnect the small line and plug it off and install the boost control on the large line? What is the small line for? It does not show the small line in the shop manual.
Any ideals?
Thanks
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
July 15, 2007, 08:13:37 am
andy2
Waste Gate Lines
July 15, 2007, 08:13:37 am »
The big line is the one you want to either plug off or use a boost controler on.The smaller line acts as a bleed and pervents oil from pooling up in the wastegate.
July 15, 2007, 08:14:43 pm
hillfolk'r
Waste Gate Lines
July 15, 2007, 08:14:43 pm »
i just put a small lawnmower inline fuel filter on the small line instead of hooking it back up to the inlet
then i plugged the hole on the inlet.....
the large hose stubis for the controller,,follow it up the the compressor "snail",,its the "boost reference line" splice in between it to add a controller
Throttle cables ftw
July 16, 2007, 12:23:28 pm
nokivasara
Waste Gate Lines
July 16, 2007, 12:23:28 pm »
Like this:
I have the MBC in the car, under the shelf under the glovecompartment:
Almost out of sight but still reachable while driving:
Caddy 1.6N/A pushing 400 000km and going strong!
July 16, 2007, 04:05:11 pm
foxracer1
Authorized Vendor
Waste Gate Lines
July 16, 2007, 04:05:11 pm »
What does that sticker say?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
July 17, 2007, 04:11:51 am
nokivasara
Waste Gate Lines
July 17, 2007, 04:11:51 am »
"the crew opens and closes the doors" It's from a Helicopter (EC-120), I used to work as a avionics mechanic.
You can click on the picture to enlarge it.
July 17, 2007, 04:28:37 am
foxracer1
Authorized Vendor
Waste Gate Lines
July 17, 2007, 04:28:37 am »
i thought i tried to enlarge it oh well it works now thanks.
91 S10 305 TPI T56
Waste Gate Lines
