Author Topic: ceramic coat the VNT housing in the -17?  (Read 3822 times)
July 11, 2007, 09:59:09 am
the4ork
  • 331
« on: July 11, 2007, 09:59:09 am »
can this be done on the inside and outside of the housing or would all the vanes have to be taken out? i'll be getting a used one... might be in my best interest to take it apart and clean the soot out of it, might as well ceramic coat it at the same time too right?
Reply #1July 11, 2007, 02:06:56 pm
foxracer1
  • 991
« Reply #1 on: July 11, 2007, 02:06:56 pm »
I have wanted to do this also and have asked on here many times getting the same answer. It was felt it would not be helpful but no real facts to back it up.
Yet i still want to do it to mine along with the manifold. I will also have a SS heat shield that wraps around the exhaust mani.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2July 16, 2007, 10:21:25 am
fastvicar
  • 154
« Reply #2 on: July 16, 2007, 10:21:25 am »
I've done it on mine.  Remove the bolts on the hot side and carefully slide the cold side out.  Then remove the vanes & clean up everything.  I had mine done by SwainTech.
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #3July 16, 2007, 03:27:50 pm
foxracer1
  • 991
« Reply #3 on: July 16, 2007, 03:27:50 pm »
What coating did you have put on it? And what do you think about it? How much do they charge. What parts did you send? I thought about send all of the hot side and having them coat the hot side of the center section.
91 S10 305 TPI T56
Reply #4July 17, 2007, 07:17:26 am
fastvicar
  • 154
« Reply #4 on: July 17, 2007, 07:17:26 am »
It's been a year or so.  I had them apply the White Lightning on the outside of the header/housing.  It is thicker than JetHot (and the like).  Because it isn't shiny it won't win beauty contests, but it was applied very nicely.  IIRC it was $125 for the manifold, with shipping.
http://www.swaintech.com/store.asp?pid=10971
Their son was a good friend of mine in college.  Good, honest people.
Reply #5July 17, 2007, 11:54:03 am
« Reply #5 on: July 17, 2007, 11:54:03 am »
Quote from: "fastvicar"
That is some cool stuff right there... If I had the funds I would send in about everything to have coated. I can only imagine how efficient and long lasting a IDI would be with everything coated.
Reply #6July 17, 2007, 12:29:04 pm
« Reply #6 on: July 17, 2007, 12:29:04 pm »
stealth coating???  :twisted:
Reply #7July 17, 2007, 02:30:22 pm
foxracer1
  • 991
« Reply #7 on: July 17, 2007, 02:30:22 pm »
So did they coat the vanes? I would like the vanes, turbine, turbine housing all coated
91 S10 305 TPI T56
Reply #8July 17, 2007, 02:33:28 pm
fastvicar
  • 154
« Reply #8 on: July 17, 2007, 02:33:28 pm »
Nope, just the hot side housing/manifold.  Coating the vanes would probably through the balance off.  They're meant to run at those temps.  We're just trying to keep the heat (and therefore, velocity) of the exhaust working in our favor by coating the manifold prior to the downpipe.
Reply #9September 06, 2007, 05:14:25 pm
subsonic
  • 1836
« Reply #9 on: September 06, 2007, 05:14:25 pm »
I just called swaintech about coating my turbine housing and exhaust manifold.  They said they would do the outside only.  They said that there is no way to coat the inside and have it stick reliably.  I was told that turbo damage would result.  If you only do the outside, the metal still gets just as hot, and expands just as much.  If it expands from glowing cherry red, the coating will crack.  It just holds the heat in the metal.  I want to keep the heat from getting in the metal, and get it out of the exhaust system as fast as possible for better spool.
Who has done the inside of thier manifold or turbine?
Reply #10September 08, 2007, 02:42:33 pm
Benjamin
  • 485
« Reply #10 on: September 08, 2007, 02:42:33 pm »
sorry for my offtopic, but why coating it  :?
Greetz, Benjamin
Must make +250hp
Reply #11September 08, 2007, 05:08:35 pm
« Reply #11 on: September 08, 2007, 05:08:35 pm »
Quote from: "Benjamin"
Greetz, Benjamin
keep heat in, for better efficiency and spool.
i think the best you can do is try to insulate the turbine housing with some of that fibreglass stuff.  coating the inside on a brand new turbo might work, but if it did ever flake off while the turbo was at full song, then be prepared for some problems...
Reply #12September 08, 2007, 11:40:17 pm
Benjamin
  • 485
« Reply #12 on: September 08, 2007, 11:40:17 pm »
sorry but a vnt17 spool so damn quick, you can make pressure at idle with this turbo even on smaller engine's than a 1.6td.
talking about efficieny, i bet you will never see any better feul mileage because its just such a little difrence.
no doubt to anyone who do coat, but i think even guys who did coated all the parts didnt saw any feul mileage benefits.
Greetz, Benjamin
Must make +250hp
