new member with a couple of questions
Topic: new member with a couple of questions (Read 3475 times)
July 09, 2007, 09:31:09 pm
mikde
Newbie
July 09, 2007, 09:31:09 pm »
Hi all. I'm a new to the vw diesel world. 3 months ago picked an 84 westy 2dr diesel. I have already done a giles pump. what a difference.
Is there a better a/c bracket available to bolt to my 1.6 n/a.
something easier to adjust and will hold a smaller sanden(rotary)
compressor?
I aquired a 1.6 turbo motor from a 85 quantum. Other than changing mounts, exhaust down pipe, and brackets will the engine bolt in?
Also I was able to do a leakdown test. all cylinders were 15% or less. Any suggestions to do to the motor before i try to install this lump.
thank you for any help or suggestions.
mike
1984 2dr rabbit diesel
July 09, 2007, 10:01:30 pm
rabbid79
July 09, 2007, 10:01:30 pm »
I guess libbybapa doesn't like you using the term 'westy' in place of 'westmoreland'. :roll: Anyway, call it what you want, even if some people don't like it, and think you should be jumped on for calling it that.
I think the oil pan and oil return like may be different too, but the core motor is the same.
'15 WRX
July 09, 2007, 10:32:34 pm
July 09, 2007, 10:32:34 pm »
get some total seal rings! :lol:
July 10, 2007, 02:28:45 pm
mikde
Newbie
July 10, 2007, 02:28:45 pm »
I'm not offended at all. I see the point. I thank you for the help.
July 10, 2007, 03:16:53 pm
July 10, 2007, 03:16:53 pm »
total seal rings??? :lol:
July 11, 2007, 07:14:30 am
rabbid79
July 11, 2007, 07:14:30 am »
My appologies Andrew. As a Rabbit enthusiast, when I saw the term 'Westy', I immediately thought of Westmoreland, but as a Vanagon enthusiast, I can see how you would have been thinking Westfalia, and hence the confusion. The fact is, the term does get used interchangeably, and I guess it depends which camp a person belongs to, as to what it means to them. I see that it wasn't an attack, and just a correction based on what the term means to you.
'15 WRX
July 11, 2007, 08:34:13 am
July 11, 2007, 08:34:13 am »
lol
July 11, 2007, 03:32:08 pm
hillfolk'r
July 11, 2007, 03:32:08 pm »
Quote from: "jtanguay"
i swear by them,not at them
most awesome setup i ever used
mine have 25-30k on them now
due to a popped head gasket,i had a gander at my cyls,they look like the day i honed them
and talk about a real drop in oil fumes+crap out the breather
i hammer my car ,and still use less than a qt of oil in 2500 miles
i run my breather open,and the underneath of my car is NOT oil covered
thanks totalseal
:wink:
Throttle cables ftw
July 11, 2007, 03:43:59 pm
Spothead
Newbie
July 11, 2007, 03:43:59 pm »
Where do you get them rings!
91 Jetta 225,000 miles
85 Golf engine 188,000 miles N/A
running on veggie oil and Biodiesel
July 16, 2007, 08:33:21 pm
hillfolk'r
July 16, 2007, 08:33:21 pm »
you gotta buy oem rings+send them to total seal so they can convert them to gapless
while you are at it,,get some dry film cyl lube too
yea thats right use the dry film lube on the cyls instead of oil
i had 5 sets of rings modded (1 spare for safety on my end in case i broke one on assembly)
dry film lube ,and ring land lube
shipped for like 130$$
if i remember right ,,it was like 17-20$$ a piece to mod an oem ring to gapless
stock geotze rings modded by total seal
its sorta like "a ring inside a ring"
Throttle cables ftw
