Author Topic: Has anyone measured cam lift and duration?  (Read 2932 times)
July 03, 2007, 08:03:30 pm
« on: July 03, 2007, 08:03:30 pm »
I'm planning on measuring all the different cams that were available for VW diesels but before I waste a bunch of my time if anyone has already done this and can let me know the info that'd be appreciated.
I have the following cams:
1.5 NA solid
1.6 TD solid
1.6 NA solid
1.6 NA hydro
1.6 TD hydro
1.9 TD hydro
I was going to set up a spare head and measure the valve height every 10 degrees or so for each cam and then post the numbers (and hopefully someone with EXCEL can graph it all)
I plan on flipping the head and taking the measurements the same way that you measure piston protrusion, unless there is an easier way?
Reply #1July 03, 2007, 11:31:21 pm
rabbid79
  • 684
« Reply #1 on: July 03, 2007, 11:31:21 pm »
I'm pretty sure someone on the Vortex has already done this.  I've seen some sort of chart which had dozens of factory cam profiles on it.  I don't know if it specifically had diesels or not, but it's probably worth looking for.
'15 WRX
Reply #2July 04, 2007, 12:11:06 am
« Reply #2 on: July 04, 2007, 12:11:06 am »
I saw it also.
I remember thinking an NA cam would give a slight EGT reduction in a Turbo application. Been a while though and my memory could be off.
Reply #3July 04, 2007, 07:51:20 am
« Reply #3 on: July 04, 2007, 07:51:20 am »
Before or after the site change over?
Any idea what section it was in?
Reply #4July 04, 2007, 05:49:55 pm
Black Smokin' Diesel
  • 656
« Reply #4 on: July 04, 2007, 05:49:55 pm »
Hydro 1.6NA, 1.6TD and 1.9TD are the same.
91 Passat syncro 1.8T swapped.
Reply #5July 04, 2007, 08:24:55 pm
« Reply #5 on: July 04, 2007, 08:24:55 pm »
Nice, that means only 3 I have to measure if I can't find that post
Reply #6July 04, 2007, 08:30:53 pm
hillfolk'r
  • 1532
« Reply #6 on: July 04, 2007, 08:30:53 pm »
i measured some years+years ago
one was from a solid 1.6na,,and i think lift was around .312(if i remember correctly)
and i thought a 1.6na hydro was like .335 or so
duration ,,,im not sure
you are on yer own there
Throttle cables ftw
Reply #7July 04, 2007, 08:36:29 pm
« Reply #7 on: July 04, 2007, 08:36:29 pm »
Does every 10 degrees sound like a good measuring distance (36 times per cycle, ~18 times per lobe) or is that not enough or excessive?
Reply #8July 05, 2007, 02:21:24 pm
foxracer1
  • Authorized Vendor
  • 991
« Reply #8 on: July 05, 2007, 02:21:24 pm »
Sounds good to me if i had what it took i would like to do it cause everyone says something different. We need some good concrete numbers.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
