internal pump pressure
Topic: internal pump pressure (Read 4039 times)
June 27, 2007, 03:50:20 pm
84Q
June 27, 2007, 03:50:20 pm »
the goal: attach a gauge to my pump so that i check on my internal pressure, and use my readings to set the pressure to spec....which i also don't know.
so, i've been reading around on a lot of threds, and have seen pics of a similar setup on a N/A, but i'm still not really sure how to go about this..? The car is an '84 Quantum TD.
June 27, 2007, 04:05:10 pm
June 27, 2007, 04:05:10 pm »
Pressure in pump MUST be 43.5 Psi at 1000 RPM engine ---more on this next time.
Pressure at 2000 Rpm -about 75.4 Psi.
as stated by hagar
June 27, 2007, 04:06:20 pm
foxracer1
Authorized Vendor
June 27, 2007, 04:06:20 pm »
Would if its more? like 7-14psi more?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
June 27, 2007, 11:00:43 pm
Benjamin
June 27, 2007, 11:00:43 pm »
Who's hagar??
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
June 28, 2007, 12:08:33 am
DA-BRT
June 28, 2007, 12:08:33 am »
Hagar is one of the dudes on VWDiesel. He's original from Denmark and a story teller.
Greetz.
Bert
-=<To>=-
For sale:
M-TDI pumps 12mm (Prepared for VAG TDI engines)
June 28, 2007, 04:07:23 pm
June 28, 2007, 04:07:23 pm »
Do you happen to have the picture that was posted regarding this?
June 28, 2007, 11:25:02 pm
June 28, 2007, 11:25:02 pm »
I think on my next pump I rebuild I'll just drill and tap a convenient spot on the lid itself... although with a turbo pump there may actually be no such spot...
Short hose to an oil pressure sensor, SPDT switch at the oil pressure gauge on the dash to switch between oil pressure and fuel pressure, and an interesting ongoing science experiment on dynamic pump pressure under varying driving conditions, temperatures, diesel additives...
So many dreams... so little time... :?
