AAZ Run-on problem
Topic: AAZ Run-on problem (Read 2685 times)
June 20, 2007, 12:28:02 pm
johnboy
User+
AAZ Run-on problem
June 20, 2007, 12:28:02 pm »
My Passat has developed a slight problem, the engine occasionally will run-on for 10-20 seconds after removing the key. I guessing that the cut off solenoid is playing up however mine is covered by the immobiliser which I believe needs breaking off to gain access. Two wires go into it.
My main question is, after removing the immobiliser, do I need to refit it? and if not,will the wiring need altering?
'96 Passat Estate AAZ.
Standard engine, 1.6Td boost pin, no EGR More boost, more fuel
Intercooler to fit next!!
June 20, 2007, 12:46:31 pm
AAZ Run-on problem
June 20, 2007, 12:46:31 pm »
sounds to me like a decent turbo timer :lol:
June 20, 2007, 02:17:38 pm
johnboy
User+
AAZ Run-on problem
June 20, 2007, 02:17:38 pm »
:roll: :roll: :roll:
June 21, 2007, 12:03:06 am
tuha
Newbie
AAZ Run-on problem
June 21, 2007, 12:03:06 am »
it could be timer for turbo(after ride it make that if you remove key engine won't stop at the moment when you remove key but 20sec 30sec 1 min later)it protect turbo
1.9 td pin 1,6td 1.0bar boost
June 21, 2007, 05:26:22 am
AAZ Run-on problem
June 21, 2007, 05:26:22 am »
Quote from: "johnboy"
when did you start noticing the 'problem'
did you recently purchase the car???
June 21, 2007, 02:08:52 pm
johnboy
User+
AAZ Run-on problem
June 21, 2007, 02:08:52 pm »
Ive had the car since last november, its only started to play up over the last couple of days. Why, do you think it could be something else?
June 22, 2007, 03:09:56 pm
johnboy
User+
AAZ Run-on problem
June 22, 2007, 03:09:56 pm »
Got an answer today. Yes the immobiliser does need smashing off, but you dont need to refit it.
One of the wires is the live to the cut off solenoid, the other is there to kill the shut off live in the evert of the car been started with a key without a transponder chip. Therefore not required unless you want to keep the car immobilised.
AAZ Run-on problem
