Author Topic: AAZ Run-on problem  (Read 2698 times)
June 20, 2007, 12:28:02 pm
johnboy
  • 45
AAZ Run-on problem
« on: June 20, 2007, 12:28:02 pm »
My Passat has developed a slight problem, the engine occasionally will run-on for 10-20 seconds after removing the key. I guessing that the cut off solenoid is playing up however mine is covered by the immobiliser which I believe needs breaking off to gain access. Two wires go into it.
My main question is, after removing the immobiliser, do I need to refit it? and if not,will the wiring need altering?
'96 Passat Estate AAZ.
Standard engine, 1.6Td boost pin, no EGR More boost, more fuel
Intercooler to fit next!!
Reply #1June 20, 2007, 12:46:31 pm
AAZ Run-on problem
« Reply #1 on: June 20, 2007, 12:46:31 pm »
sounds to me like a decent turbo timer  :lol:
Reply #2June 20, 2007, 02:17:38 pm
johnboy
  • 45
AAZ Run-on problem
« Reply #2 on: June 20, 2007, 02:17:38 pm »
:roll:  :roll:  :roll:
Reply #3June 21, 2007, 12:03:06 am
tuha
  • 4
    • http://www.vwgolf.pl
AAZ Run-on problem
« Reply #3 on: June 21, 2007, 12:03:06 am »
it could be timer for turbo(after ride it make that if you remove key engine won't stop at the moment when you remove key but 20sec  30sec 1 min later)it protect turbo
1.9 td pin 1,6td 1.0bar boost
Reply #4June 21, 2007, 05:26:22 am
AAZ Run-on problem
« Reply #4 on: June 21, 2007, 05:26:22 am »
Quote from: "johnboy"
when did you start noticing the 'problem' ??? did you recently purchase the car???
Reply #5June 21, 2007, 02:08:52 pm
johnboy
  • 45
AAZ Run-on problem
« Reply #5 on: June 21, 2007, 02:08:52 pm »
Ive had the car since last november, its only started to play up over the last couple of days. Why, do you think it could be something else?
Reply #6June 22, 2007, 03:09:56 pm
johnboy
  • 45
AAZ Run-on problem
« Reply #6 on: June 22, 2007, 03:09:56 pm »
Got an answer today. Yes the immobiliser does need smashing off, but you dont need to refit it.
One of the wires is the live to the cut off solenoid, the other is there to kill the shut off live in the evert of the car been started with a key without a transponder chip. Therefore not required unless you want to keep the car immobilised.
