Author Topic: Cannot time the injection pump, WTH is wrong?  (Read 9297 times)
May 24, 2007, 08:01:21 am
Black Smokin' Diesel
  • 656
« on: May 24, 2007, 08:01:21 am »
I had the Jetta TD (87) towed to a vw shop this morning so I could get the timing properly done. As it turns out, the pump cannot be timed. The dial gauge reads nothing, zero, niet, nada. This shop has a pretty good reputation and with the amount of VW diesels in quebec, I have no doubt they know how they work.
Here's a short resume of what work I did on the engine. I replaced the head, injectors (mercedes, known to be good) and heatshields, new glowplugs, new lifters and used a 1.9TD headgasket. Replaced the crank, intermediate shaft and cam seal, new timing belt and tensionner, aluminum thermostat housing and non-tracked IS pulley were used. There's a bit more but you get the idea.
I got the engine running yesterday. It smoked badly, had little power and the injectors were loud as hell (big rig loud). After three to four minutes, the engine shut off and never started again. I replaced the head because one of the injector boss was cracked. The HG was due for along with the TB. Prior to all this, the engine had started to develop a loud injector knocking. This was the breaking point for me and decided to get dirty. The only thing the engine does is crank and crank and crank. Sometimes it starts for one or two seconds but dies immediatley even when giving it gas. My guess is that fuel accumulates in the cylinder and ignites briefly.
Now the car is sitting docks, with an injection pump that can't be timed. Any ideas as to why the IP can't be timed?
Here are some pics of the car, just for kicks.
Who can tell me what the sensor located on the crankcase vent tube near the intake tube is for?
Reply #1May 24, 2007, 08:12:10 am
« Reply #1 on: May 24, 2007, 08:12:10 am »
If the dial indicator shows nothing, I'd guess the pump is hosed. You sure the pully isn't slipping on the shaft?
Reply #2May 24, 2007, 08:17:07 am
  • 656
« Reply #2 on: May 24, 2007, 08:17:07 am »
Quote from: "jimfoo"
Pulley is on tight, I torqued it at 33lb-ft like the bentley says, with a locking washer.
Quote from: "libbybapa"
If it starts at all, then the plunger IS moving and the reading of "0" on the dial indicator is an error.
Andrew
So the dial would be faulty? Could bad injectors cause this?
Reply #3May 24, 2007, 08:25:10 am
« Reply #3 on: May 24, 2007, 08:25:10 am »
Maybe they don't have the correct dial indicator, one long enough to contact the plunger? What if you loosen the bolts on the IP enough to be able to move it, have someone try to start the car, and try rotating the pump?
Reply #4May 24, 2007, 08:46:05 am
  • 656
« Reply #4 on: May 24, 2007, 08:46:05 am »
As Jimfoo suggested, you are sure the key is installed in the pump shaft and that the sprocket is not spinning on the shaft, right?
Andrew
100% positive. I check it, and the shop did too.
I already tried that but to no avail.
Reply #5May 24, 2007, 08:50:18 am
  • 656
« Reply #5 on: May 24, 2007, 08:50:18 am »
Bad injectors won't cause a "0" reading on the dial indicator.  The dial indicator shows the movement of the plunger in the pump.  If the dial indicator is giving an accurate reading of "0", then the plunger would not be moving.  In that case no fuel would be injected at all and there would be no signs of life with the motor.  If is starts at all, even for brief spurts, then the person using the dial indicator is not doing it correctly.
Andrew
Well the guy there told me how they time the pump and it was the same as described by the bentley. The gauge didn't seem broken, it moved with slight pressure on the needle.
Reply #6May 24, 2007, 09:22:29 am
« Reply #6 on: May 24, 2007, 09:22:29 am »
If that's the case, then it sounds like the pump is hosed. Maybe something snapped inside and allowed it to turn somewhat, but the more it turned, the more it wore down until now it just slips?
Reply #7May 24, 2007, 09:26:50 am
  • 656
« Reply #7 on: May 24, 2007, 09:26:50 am »
Maybe. Prior to replacing the head, the injectors started to knock a lot and the car lost power. After the swap it was extremely loud, had no power. Now it just won't start.
Reply #8May 24, 2007, 09:31:30 am
« Reply #8 on: May 24, 2007, 09:31:30 am »
Well hopefully it isn't to bad to fix. Maybe time for a Giles pump.  :wink:
Reply #9May 24, 2007, 09:33:29 am
rallydiesel
  • 1880
« Reply #9 on: May 24, 2007, 09:33:29 am »
I believe the sensor on the CCV tube is not a sensor at all, but a simple heater so ice doesn't form and clog the CCV tube in cold weather.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10May 24, 2007, 09:46:28 am
  • 656
« Reply #10 on: May 24, 2007, 09:46:28 am »
I'd love to but my budget is low. I'm just a poor student :P
Quote from: "rallydiesel"
Interesting. Thanks for the answer.
Reply #11May 24, 2007, 11:54:24 am
  • 656
« Reply #11 on: May 24, 2007, 11:54:24 am »
I would pull the timing plug bolt out and use a small screwdriver as a feeler while I rotated the engine by hand.  The end of the plunger (which the screwdriver should be touching) should move in and out 1/8" twice per crank rotation (4 times per pump rotation).  If it does, then the dial indicator was not used correctly.  If it doesn't, then the pump is toast.
Regardless, if the plunger was not moving you would not even get a sputter from the engine.
Andrew
If the pump is good and the plunger is moving, why won't it start? The pump is timed approximately using the marks on the pump and pulley, shouldn't it at least idle?
Reply #12May 24, 2007, 07:41:34 pm
mk2diesel
  • 60
« Reply #12 on: May 24, 2007, 07:41:34 pm »
its not qiute that simple  with diesels ....   the pump has to be timed in a certain range ( for proper fuel dispersion ... etc) or the engine won't fire at all ... a couple of mm either way will make it impossible to even start it .... spec for 1.6 na  is .89 mm - .96 mm      either side of this and its a no go situation ....
Reply #13May 24, 2007, 07:53:32 pm
« Reply #13 on: May 24, 2007, 07:53:32 pm »
Quote from: "mk2diesel"
i've my 1.6TD set to around 1.06 or so...
Reply #14May 24, 2007, 09:00:29 pm
« Reply #14 on: May 24, 2007, 09:00:29 pm »
Crack the injector lines open and crank the car over, see if you are getting any fuel. I'm sure you are familiar with the checks if you aren't.
I agree that you should try the screwdriver method
