Author Topic: AZZ in MK2 questions  (Read 5271 times)
May 22, 2007, 06:41:22 pm
1slowvw
« on: May 22, 2007, 06:41:22 pm »
hey guys I finaly found a mk2 Jetta worth saving, to start my AZZ powerd mk2 project. I just have a couple questions. First off will the 1.6 tannny bolt up to the 1.9 without a problem, and will i need 1.9 motomounts to make the azz fit? are there any other clearance issues i should be worried about? let me guys know, any help would be greatly apreciated, and eventualy repaid with pictures.
1SlowVW
Reply #1May 23, 2007, 12:09:06 am
« Reply #1 on: May 23, 2007, 12:09:06 am »
as far as i know everything bolts right up... it's like grown up lego.
i'm going to be installing the earlier TDI 1Z engine into my MK2 jetta  :wink:
Reply #2May 24, 2007, 06:34:12 pm
1slowvw
« Reply #2 on: May 24, 2007, 06:34:12 pm »
thats exactly what i wanted to here, thanks. Anyone got pics of a 1.9 in a mk2, just want to see how tight it is, and see where a good place to put an intercooler would be.
1SlowVW
Reply #3May 24, 2007, 09:15:22 pm
« Reply #3 on: May 24, 2007, 09:15:22 pm »
Although I have not installed a 1.9 TD into a mk2 I have removed one and I also installed a 1.6TD into a mk3.
Motor mounts : you need the mk2 ones, the mk3 ones are different. The bolt right up to the block though
tranny: Any 8v tranny bolts up to any 8v engine, gas, diesel it's all the same. The mk3 tranny is ALOT taller then the one in the mk2 so I'd considier swapping it in. If you do, mk3s have 100mm hubs on the tranny, mk2s usually have 90mm.
Pump: The mk3 pump has 3 wiring connections IIRC, mk2s only have 1. Not sure how to get around this, you probably just need power to the stop solenoid to make it run
coolant sensors: mk2 and mk3 are different but all you need to do is swap the coolant flanges from the mk2 onto the mk3.
Exhaust: you'll need the mk2 DP setup (the one bolted to the turbo) or customize the rest of your exhaust to go with the mk3 DP
Alternators: slightly different wire connections, all you need is a soldering gun
Starter: Use the mk2 starter
I think that's it
Reply #4May 25, 2007, 07:15:06 pm
1slowvw
« Reply #4 on: May 25, 2007, 07:15:06 pm »
Great info guys, that is exactly what i wanted to hear, I think i will soon be picking up a jetta, and a AZZ, with a couple turbo's, should make a great summer project.
1SlowVW
