Glow plug light on the dash stays on?
Topic: Glow plug light on the dash stays on? (Read 2265 times)
May 13, 2007, 10:50:48 pm
Barry W
May 13, 2007, 10:50:48 pm »
Hello,
I got a quick question. On my parts car the glow plug light go's on when you first turn the ignition on and then turns off as usual. But 10 seconds after its started the light comes back on. Is this normal?
May 14, 2007, 07:57:10 am
May 14, 2007, 07:57:10 am »
If it is a mk2 the water sensor in the water/fuel seperator under the car at the back is either full of water or is mal functioning.
May 14, 2007, 09:19:28 pm
Barry W
May 14, 2007, 09:19:28 pm »
ahh ok good to know. So not a big motor problem then, seeing as its a parts car.
May 20, 2007, 10:02:27 pm
janb
May 20, 2007, 10:02:27 pm »
mk2 also prone to a 'cluster' issue, usually a ground,
Of my (6) A2's only one has a GP light that works correctly, sometimes they blink, sometimes stay on, sometimes don't work... it is best to install a direct feed from Buss bar to light
The Stealth Rabbit
VW-d's are forever
