Author Topic: Oil warning light  (Read 2695 times)
May 12, 2007, 09:27:15 pm
dirtydiesel
  • 35
Oil warning light
« on: May 12, 2007, 09:27:15 pm »
Cruising down the highway, Oil light and buzzer came on, and lost power brakes. Removed vaccum pump first,oil pump seems fine. Intermediate shaft seems fine, tried new vaccum pump still no luck. 1.9 turbo diesel. Any Suggestions?
Reply #1May 12, 2007, 09:36:31 pm
Oil warning light
« Reply #1 on: May 12, 2007, 09:36:31 pm »
sounds to me like an electrical problem..
what year and make is the car?
Reply #2May 12, 2007, 09:40:07 pm
  • 3255
    • My collection of HOWTOs
Oil warning light
« Reply #2 on: May 12, 2007, 09:40:07 pm »
It really really really sounds like your intermediate shaft is not turning... sorry to be so obvious but you'v turned the engine over and confirmed that the shaft is turning properly ?  Timing belt is OK ??  IM shaft sprocket isn't loose and spinning on the shaft ??
Very very rare for oil pumps to just quit internally... usually they just wear  and lose pressure over time.  you could spin it with an electric drill to see if it's still capable of producing pressure.
But that doesn't explain the sudden loss of vacuum at the same time...
Reply #3May 13, 2007, 04:31:31 am
dirtydiesel
  • 35
oil light
« Reply #3 on: May 13, 2007, 04:31:31 am »
pretty sure that i have no oil preesure because the turbo growls after i shut the car off. ,and the brake pdeal stays hard. i rocked the car in gear and the intermidate shaft moves, and i can move the oil pump shaft and you can hear oil moving. hte oil pump drive is very worn but still fine enough to turn with the vaccum pump. car is a 1989 jetta .
Reply #4May 13, 2007, 07:16:04 am
QuickTD
  • 1156
Oil warning light
« Reply #4 on: May 13, 2007, 07:16:04 am »
Even though the I-shaft turns when rotating the engine by hand it may not deliver enough power at operating speed. It takes considerable torque to drive the oil pump. If the key is stripped in the intermediate shaft pulley it may not be able to deliver that torque.
Reply #5May 13, 2007, 06:48:53 pm
tylernt
  • 344
Oil warning light
« Reply #5 on: May 13, 2007, 06:48:53 pm »
Yeah if your timing belt is loose then the belt may be slipping on that smooth pulley at higher RPM. I seem to recall that several people have found broken plastic bits in their oil pump pickup, this will make the oil pump work harder and make the belt more likely to slip on that pulley.
'82 Diesel Rabbit, '88 Fox RIP, '88 Jetta (work in progress)
Reply #6May 13, 2007, 08:49:38 pm
Oil warning light
« Reply #6 on: May 13, 2007, 08:49:38 pm »
yea starting to sound like a pretty huge problem at this point... turbo growling... uh oh!
Reply #7May 15, 2007, 06:50:44 pm
dirtydiesel
  • 35
Oil warning light
« Reply #7 on: May 15, 2007, 06:50:44 pm »
found the problem it was a water pump bolt  backed out and jammed the inter shaft pulley. i was very lucky all fixed up nom. it gave me an excuse to install my GT 15 turbo. works insanely crazy. thanks evrybody for your help.
