1.9L D/ TD engine block
Topic: 1.9L D/ TD engine block (Read 4028 times)
December 27, 2004, 08:17:18 am
DieselMonkey
December 27, 2004, 08:17:18 am »
Guys,
In relation to my 1.9L D > TD conversion. I was under the car today and noticed the back of my block has in the casting, 1.9 D/ TD.
Its a 1997 engine.
Is it possible this 1.9D has under piston cooling ?
December 27, 2004, 01:03:39 pm
December 27, 2004, 01:03:39 pm »
you mean oil squirters? maybe... someone is bound to know in this forum though
December 27, 2004, 02:57:09 pm
srivett
December 27, 2004, 02:57:09 pm »
Yes they use the same block. You just need all of the parts to put on the outside.
Steve
1992 1.6D Golf - 412K km
Mint except for chipped paint, no rust
December 27, 2004, 04:02:05 pm
DieselMonkey
December 27, 2004, 04:02:05 pm »
Yes the block is the same i'm quite sure, but as for the oil cooling jets, i am unsure. I havent pulled the pan yet to check, but i think it is very unlikely it has them.
I would have pulled it and checked sooner, but i'm not at that stage in the project and i'm not draining £30 of oil to check something that if in place or not, would stop the K03 going on. But i would be very pleased if they where there.
If anyone knows for sure if the jets are in this block, i'd be more than greatful if you could let me know.
But if they where in place, it would just seem so wrong wouldnt it ! :lol:
December 27, 2004, 10:13:29 pm
MK3 GTD
User+
December 27, 2004, 10:13:29 pm »
does it still have the turbo oil return port in the back of the block? if it does than i would believe that it should also have the oil jets
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
December 28, 2004, 03:42:06 am
DieselMonkey
December 28, 2004, 03:42:06 am »
Where the drain back should be bolted up, is a drilled and tapped hole that hasnt went right through into the block. So no, it doesnt have an operative / blanked off oil return. I'm using a 1.6L GTD pan with drain-back for this.
December 28, 2004, 05:27:40 am
Justin
December 28, 2004, 05:27:40 am »
even if it doesnt have the jets in the block couldnt you do like BMW does now and drill a small hole on the top of the rod by the rod journal and have it directed at the piston to cool it, you would also need to drill the rod bearing so that oil would go through your hole in the rod
just food for thought if you really wanted oil cooled pistons
www.archeryprostaffmi.com
