Author Topic: Bosch injection pump throttle damper?  (Read 4049 times)
December 20, 2004, 08:08:11 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« on: December 20, 2004, 08:08:11 am »
My thottle damper (part 11) squelches if it opperate the throttle by hand, Is is needed and should I replace it?
11     028 130 249     DAMPER
Cheers
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #1December 20, 2004, 09:29:28 am
fspGTD
  • 1529
« Reply #1 on: December 20, 2004, 09:29:28 am »
I have not had an opportunity to play with a governor linkage like that with a damper, but if I understand correctly, it delays movement of the throttle input lever to the governor inside the pump relative to the throttle lever you control with your foot.  In that case, for a performance application, you might want to try running without it.  I think you might then find that you have more power (probably with a bit more smoke too) when you suddenly mash down on the throttle, and you might find that the turbo also spools up quicker.  :twisted:  Good luck!
Jake Russell
Reply #2December 21, 2004, 07:52:48 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
Damper
« Reply #2 on: December 21, 2004, 07:52:48 pm »
hey guys
yes you're right about the damper it's designed to make sure u don't
have any black smoke on sudden acceleration.
I have noticed on almost all of the pumps that i rebuild in my shop
that the damper is not dampning any more. it is a vw part and i'm
pretty sure it's not cheap.
i would also just leave it alon or remove it totally.
Giles
Reply #3December 22, 2004, 03:56:44 am
GTD.
  • 183
Re: Damper
« Reply #3 on: December 22, 2004, 03:56:44 am »
Quote from: "Giles@superiorFuelInj"
hey guys
Giles
Yeah I dont think mine is damping any more it sounds like a knackered boot strut.
I would have thought they'd be available from Bosch? as they make the pumps anyway.
[Oo=w=oO]Golf GTD
