Author Topic: CCV Filter?  (Read 10516 times)
April 27, 2007, 10:35:53 am
stewardc
CCV Filter?
« on: April 27, 2007, 10:35:53 am »
I am looking for a nice, efficient and cheap filter to filter the oil out of the crankcase ventillation system. What is everyone running?
Reply #1April 30, 2007, 08:51:31 am
stewardc
CCV Filter?
« Reply #1 on: April 30, 2007, 08:51:31 am »
Bump anyone ??
Reply #2April 30, 2007, 08:56:15 am
BlackTieTD
  • 1512
CCV Filter?
« Reply #2 on: April 30, 2007, 08:56:15 am »
are you venting to atmosphere or trying to filter out oil vapour to keep it out of the intake?
i've seen steel wool in some type of case used to get the oil to pool and collect it doesn't go into the intake.
if you are venting to atmosphere, there are little breather filters you can get but i've always been a little leary of those... don't want to overpressurize......  :?
when i've vented cars to atmosphere before i've just used a piece of clean cloth over the opening to keep crap out, so there is no risk of overpressurization.
Reply #3April 30, 2007, 09:29:57 am
stewardc
CCV Filter?
« Reply #3 on: April 30, 2007, 09:29:57 am »
I'd like to vent back into the intake, but keep oil out of the intake tract.
Reply #4April 30, 2007, 09:35:05 am
CCV Filter?
« Reply #4 on: April 30, 2007, 09:35:05 am »
My brother has something similar hooked up on his gas chevette. It's simply a bottle with a mesh filter in it hooked up inline with the CCV hose, he bought it at c-tire IIRC
Reply #5April 30, 2007, 09:42:31 am
BlackTieTD
  • 1512
CCV Filter?
« Reply #5 on: April 30, 2007, 09:42:31 am »
then you can rig something up with stainless steel wool. it will make the oil vapour pool up into a liquid.
Reply #6May 02, 2007, 06:27:33 am
rubadubdub
  • 109
CCV Filter?
« Reply #6 on: May 02, 2007, 06:27:33 am »
im sure i've read posts on here about this. From memory all the ones ive read about were just metal cans or tubes with 2 pipes, one from head other to air intake, maybe with steel wool in the tank to catch the oil.
Maybe try searching for 'runaway' as i think thats what the homemade CCV  were trying to solve.
1991 Mk2 Golf GTD
Reply #7May 02, 2007, 07:30:49 am
CCV Filter?
« Reply #7 on: May 02, 2007, 07:30:49 am »
Guess that's something I'd never have to worry about with an oil bath air filter, unless I tipped on my side. Oh wait, I've done that before. :shock:
Reply #8May 02, 2007, 08:17:53 am
saurkraut
  • 904
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #9May 02, 2007, 09:31:42 am
CCV Filter?
« Reply #9 on: May 02, 2007, 09:31:42 am »
why not just vent to the atmosphere?
Reply #10May 02, 2007, 06:58:11 pm
Kudagra
  • 738
    • www.no-coast.com
CCV Filter?
« Reply #10 on: May 02, 2007, 06:58:11 pm »
Quote from: "Trev0rbr"
Sure...and it keeps the rust away too!!
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #11May 03, 2007, 09:47:45 am
saurkraut
  • 904
CCV Filter?
« Reply #11 on: May 03, 2007, 09:47:45 am »
Environmental stuff aside, there is a performance benifit to run the crank case at a pressure slightly below atmospheric pressure.
I forgot where i read it, and I don't remember how much the bennifit is.
If you look at both the TD and NA intakes, they both look some what restrictive.  I suspect the VW engineers designed them this way for that purpose.  And if you've ever held a finger over the crank case vent, even on a good engine, there is positive pressure.  Perhaps the intake restriction is made up by the crank case blow by.
So by tossing our stock aircleaners for a "free flowing" design, or venting our crank cases to atmosphere, are we losing something?
Environmental stuff aside.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #12May 03, 2007, 10:31:58 am
Kudagra
  • 738
    • www.no-coast.com
CCV Filter?
« Reply #12 on: May 03, 2007, 10:31:58 am »
When you get into high end drag racing stuff alot of people use Vacuum pumps to put negative atmospheres on the crankcase. All that does is take the atomized oil vapor out of the way of the crank and the pressure from the bottem side of the pistons. On our engines I dont think you would notice a bit even on a dyno.
Best to just use a catch can.
Reply #13May 03, 2007, 11:07:50 am
saurkraut
  • 904
CCV Filter?
« Reply #13 on: May 03, 2007, 11:07:50 am »
So people that live and die by maximum HP will give up some to run a vacuum pump?
Make you wonder, don't it?
The thing I recall is it helped the rings seal better too.
Watch that catch can in the winter.  There is water in the blow by too.  If she ices up and plugs, you'll be blowing seals in short order.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #14May 03, 2007, 06:19:35 pm
insdtanoodles
  • 148
CCV Filter?
« Reply #14 on: May 03, 2007, 06:19:35 pm »
Quote from: "saurkraut"
that is exactly what happened to me, didnt blow out any seals but the whole catch can for the oil was frozen solid. Looking for an alternative right now but I dont really want to vent into the atmosphere because it is not good for the environment.
1996 vw jetta AAZ
