Author Topic: GTD Problems  (Read 4772 times)
April 23, 2007, 08:39:16 am
MontanaGTD
  • 230
    • http://www.dub-style.com
GTD Problems
« on: April 23, 2007, 08:39:16 am »
I'm currently rest up at home off sick from work for a month after a couple of operations on my legback and legs - so the GTD hasnt moved for a while. Just been out to it today to run it for the first time in ages, checked my water level - oil sludge on top of the water again. Checked the oil filler cap nice black oil no mayo. But on checking the dipstick it had thick mud sludge on the bottom of the dipstick and took a couple of dips to check.
I just had a new oil cooler, water cooler and timing belt done. I think there is still left over oil in the water system, what is the best way of cleaning it out? Ive tried coolant flush twice and its still coming through into the expansion tank. I've been told the best thing to use is a non-foaming dish washer tablet with the car on tickover and the expansion bottle top off, for 20 minutes or so. then drain it.
It now needs a new thermostat too, as its jammed solid, so it needs flushed through and maybe a good oil service too.
Anyone got any other ideas - Couldnt be the head gasket could it?
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #1April 23, 2007, 06:03:12 pm
GTD Problems
« Reply #1 on: April 23, 2007, 06:03:12 pm »
it could be the head gasket.. if you pressure test the coolant system, that should be a good indicator of whether or not it is the culprit.
i had same problems with my oil cooler when it went.  i wouldn't drive the car 10 feet unless i had to if the oil was sludging etc like yours is.  immediately drain the crap and put in fresh cheap oil.. maybe run it with one of those detergent additives... check it again and i would even drain it again just to be safe.
good luck! hope it's not your HG!
Reply #2April 24, 2007, 02:05:21 am
MontanaGTD
  • 230
GTD Problems
« Reply #2 on: April 24, 2007, 02:05:21 am »
surely if it was the h/g it would go quickly? I've done over 33000 miles with this problem coming and going!
MK3 Polo G40 - Sold
Reply #3April 24, 2007, 09:35:28 am
GTD Problems
« Reply #3 on: April 24, 2007, 09:35:28 am »
are you running stock boost?
Reply #4April 27, 2007, 01:43:59 pm
MontanaGTD
  • 230
GTD Problems
« Reply #4 on: April 27, 2007, 01:43:59 pm »
yes - I was about to start fitting all my fun parts, but the rev counter died so i started checking things under the bonnet first. And thats what i found!
MK3 Polo G40 - Sold
