General Information
General
Will be changing drive flange seals - any tips?
Topic: Will be changing drive flange seals - any tips? (Read 5135 times)
April 15, 2007, 07:32:17 am
rallydiesel
April 15, 2007, 07:32:17 am »
I will be changing both drive shafts and I figure I may as well do the flange seals as well. I think I have the mini-slip thingy as I can see a green sleeve on the passenger side drive flange. Does this change anything about the seal change?
I may also just drop the tranny at this point and put a new rear crank seal because it is leaking. Any tips on this job? Do you need to use new flywheel bolts?
1991 Jetta TD - sold
2001 Golf TDI - Son's
April 15, 2007, 08:22:36 am
rallydiesel
April 15, 2007, 08:22:36 am »
Also, is there anyplace that sells the actual flanges? I can't seem to find them on any of the parts sites.
April 15, 2007, 04:34:10 pm
April 15, 2007, 04:34:10 pm »
reuse the flywheel bolts, they are 9mm 12pt bolts
April 16, 2007, 08:11:45 am
April 16, 2007, 08:11:45 am »
Use a puller or at least a ratchet-strap around the tranny and flanges so you can compress them to get the circlip out. Also, my puller slipped when I pulled off the circlip and the flange fired straight at my head at about 100 mph, would have probably knocked me unconscious if it had hit! Be careful. The "mini-slip" as it's called has much higher spring tension on it.
84 Scirocco 8v <-- TDI in progress
01 Jeep TJ 4.0
'86 Golf N/A Diesel -->Wife's car
April 16, 2007, 09:10:52 am
duffer
April 16, 2007, 09:10:52 am »
I believe you can get new flanges
at
www.GermanAutoParts.com
for around $40 US.
April 16, 2007, 09:22:19 am
April 16, 2007, 09:22:19 am »
www.brokevw.com
has an excellent picture of a home made puller
April 16, 2007, 07:35:16 pm
rallydiesel
April 16, 2007, 07:35:16 pm »
Thanks!
April 26, 2007, 07:53:58 am
Op-Ivy
April 26, 2007, 07:53:58 am »
I made a DIY a while ago using a homemade tool as well.
http://www.vwdieselparts.com/forum/viewtopic.php?t=6352
-Matt
General Information
General
