Author Topic: timing troubles with tdi-m  (Read 4640 times)
April 12, 2007, 09:15:58 am
norm53
  • 3
« on: April 12, 2007, 09:15:58 am »
I've got a 97 tdi 1.9 with a mechanical pump from a 86 td jetta.  I set the timing @1mm of lift at tdc.  I couldn't get it to fire at all.  I rechecked the valve timing, pump timing, fuel delivery, and everything else I could think of.  I finally tryed advancing the timing and got it to run well @2 mm lift at tdc.  I'm thinking that the direct injection injectors open at a higher pressure than the 86 indirect injectors so they open later in the stroke - therefore retarding the injection.  Have any of you who have made the conversion to mechanical pumps experienced this?  How do I time the pump and what degree do I time it too?  It seems like a crap shoot and I'd rather not have any holes in the top of my pistons!!  Thanks! Norm
Lets make it green!
Reply #1April 12, 2007, 11:26:52 am
Tintin
  • 1279
« Reply #1 on: April 12, 2007, 11:26:52 am »
Humm, y do not have a great deal to make with a 1.6 pump  on a TDI engine, keep the timing at 2mm and drive with, nothing other to make....
Probably 40-50HP maximum.
That takes anything other that a specific DI pump for these engines.
I have some mechanical 10mm pump in stock adapted for the TDI, good for daily driving and good for 130-140HP.
Reply #2April 12, 2007, 03:52:29 pm
« Reply #2 on: April 12, 2007, 03:52:29 pm »
Quote from: "Named Tintin"
how much do you sell your pumps for ?
Reply #3April 16, 2007, 08:19:53 am
« Reply #3 on: April 16, 2007, 08:19:53 am »
Yeah, Ditto!  ;)
-Brendan
Reply #4July 03, 2007, 08:41:36 pm
hillfolk'r
  • 1532
« Reply #4 on: July 03, 2007, 08:41:36 pm »
like i said before ,,set it up with a 12mm head,then you got plenty of fuel
kevin@r+r engine can do ya right for like 400 if you have the pump,and 12mm head from a cummins ve pump
800-722-2000
Throttle cables ftw
Reply #5July 06, 2007, 04:32:22 pm
scopefrfd
  • 289
« Reply #5 on: July 06, 2007, 04:32:22 pm »
I'm really surprised that it takes 2.mm of static timing to get it running....I think the pump head you have is worn out.  Overland used to sell a M-tdi kit for vanagons that used the 9mm pump head and they ran fine not huge hp #'s but it did produce what a stock tdi does.  Remember a tdi only has a 10mm pump head, except auto's 11mm.  I have an 11mm pump head on my M-tdi and @ 1.00mm pump timing it sounds as loud as a Cummings.  I could get away with .80'sish mm timing if I wanted to quite it down.
You're probably going to need a new pump head soon so might as well get an 11mm or 12mm pump if you can.
Reply #6July 21, 2007, 02:46:48 pm
GermanAutoMan
  • 2
Re: timing troubles with tdi-m
« Reply #6 on: July 21, 2007, 02:46:48 pm »
Quote from: "norm53"
so how did you fix your car. I think i'm having the same problem
Reply #7July 23, 2007, 08:50:29 pm
hillfolk'r
  • 1532
« Reply #7 on: July 23, 2007, 08:50:29 pm »
i set mine to stock 1.6td specs.....
i started at .7  and worked my way up
at .7 it was horrible
i think its at .99-1.01 or so right now
somethins wierd with your pump
we even set therabbittrees pump to that spec+it was fine
after he removed that wierd head with the spring thing under the plunger,,cause it "wouldnt time right at all"
Throttle cables ftw
