Author Topic: Replacing a transmission, question.  (Read 6016 times)
March 31, 2007, 06:30:59 pm
DieselSteed
  • 107
« on: March 31, 2007, 06:30:59 pm »
Now that the warmer weather has finally arrived, its time for me to finish up some projects I have been neglecting during the winter, and replacing a transmission in my '87 Jetta is one of them. It looks like I can replace it without removing the engine from the car. My questions are: Has anyone else attempted this shortcut? How big a pain is it? Thanks in advance.
When my lady really wants to get me in the mood, she rubs a little diesel behind her ears.
Reply #1March 31, 2007, 06:34:35 pm
« Reply #1 on: March 31, 2007, 06:34:35 pm »
yea you can leave the engine in place for sure.  just raise the car up, leave the cv's on the car, unbolt the motor from tranny, remove the one tranny mount and it will come clean (after you disconnect the speedo cable, and clutch cable.
a friend who works on gm cars was so impressed by how easy it was to remove everything... even more impressed by the way that the front rad support comes out so i could get right in there and clean some crap out  :lol: just get a nice little stool and go to town!
Reply #2March 31, 2007, 07:05:25 pm
DieselSteed
  • 107
« Reply #2 on: March 31, 2007, 07:05:25 pm »
Thanks. I'll give it a shot tomorrow.
Reply #3March 31, 2007, 08:47:53 pm
« Reply #3 on: March 31, 2007, 08:47:53 pm »
You need to support the engine. Either with a 2X4 across the fenders (on the inner lip, not on the tops of them) with an eye hook type deal that you can tighten or lower in the middle (for supporting the engine).
You can just use a jack(stand) under the oilpan if you want.
Make sure you have the correct bit for the CV bolts or you'll make the job 100X harder
Reply #4March 31, 2007, 09:22:57 pm
« Reply #4 on: March 31, 2007, 09:22:57 pm »
Quote from: "burn_your_money"
yea i forgot to mention the support engine part!
the transmission can be held by the cv's and the one mount though.
yea 8mm 12 point tool! its special and runs what... $20? or so? i've tried taking those bolts without it... what a PITA!
Reply #5March 31, 2007, 09:57:40 pm
« Reply #5 on: March 31, 2007, 09:57:40 pm »
you can get them at autozone for $8 or c-tire for $20 and you get a pack of four, includes the 12mm for the head
Reply #6April 01, 2007, 07:19:05 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #6 on: April 01, 2007, 07:19:05 am »
#1 thing to remember when using those 12 point (tripple square) tools.  PERFECTLY CLEAN out the hole before even trying to put the tool in. Just a little crud doesnt let it fully insert into the bolt and it will get fookered up. Best is using a pick to loosen up the packed in stuff then blow it out with compressed air.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #7April 01, 2007, 07:39:50 am
« Reply #7 on: April 01, 2007, 07:39:50 am »
and then hammer the tool in there to ensure a solid fit.
Reply #8April 01, 2007, 12:31:17 pm
« Reply #8 on: April 01, 2007, 12:31:17 pm »
i didn't even clean the bolts... just hammered em in!  :oops:  what a pain to take off afterwards though!  :lol:
Reply #9April 01, 2007, 05:03:51 pm
insdtanoodles
  • 148
« Reply #9 on: April 01, 2007, 05:03:51 pm »
I tried the remove transmission without taking the engine out and it was such a PITA, it would have been much easier if I took the front bumper off and removed the rad for easier access.
1996 vw jetta AAZ
Reply #10April 01, 2007, 06:08:00 pm
« Reply #10 on: April 01, 2007, 06:08:00 pm »
i'm not a fan of removing the tranny, but it is a fairly quick job, it's even easier on a mk1 as compared to a mk2
Reply #11April 01, 2007, 07:36:15 pm
« Reply #11 on: April 01, 2007, 07:36:15 pm »
everything is easier on a mk1, I worked on my first mk3 today, what a pain that was
Reply #12April 01, 2007, 08:43:50 pm
« Reply #12 on: April 01, 2007, 08:43:50 pm »
i guess the only real trouble with removing the tranny with engine installed is getting at the right side CV bolts... i've done it with the car dripping in my face lol. that sucked!
Reply #13April 02, 2007, 07:47:14 am
DieselSteed
  • 107
« Reply #13 on: April 02, 2007, 07:47:14 am »
Thanks for the reply guys. The tranny is out and it seems it stuck on everything on the way out but it is out with the engine still in the car :lol: The job was cut short because it started raining.
