"has this motor had the TDI crank fix installed???" What would this be?
if the pump timing is not set correct could this make any difference?the 1.6 looked faster because it was on a golf II that is lighter than golf III...could be that :idea:
Quote from: rtmx"has this motor had the TDI crank fix installed???" What would this be?That would be machining the crank to accept a TDI sprocket, I believe. Mainly intended to prevent the crankshaft nose from tearing apart at the keyway. The amount of power involved in a 1.9 is apparently sufficient to eventually cause the metal to fail at that point; a TDI sprocket has no keyway, instead holding position through the D-shape of the crank hole.Did I get that right, gurus?
Quote from: carrizog60if the pump timing is not set correct could this make any difference?the 1.6 looked faster because it was on a golf II that is lighter than golf III...could be that :idea:Nope, the Golf II's got 55 kW this one's got 75...
