Author Topic: Crap, I'm screwed  (Read 6688 times)
March 04, 2007, 05:11:28 pm
Crap, I'm screwed
« on: March 04, 2007, 05:11:28 pm »
As you may or may not remember, I was putting a VNT 15 on my AAZ in my Land Rover. Guess when I bought it, I didn't think about it hanging down further. The exhaust sits right in the middle of my starter. :evil:  I would still like to put a variable nozzle turbo on it. What, if any, are my options? I assume some of the other ones are separate from the manifold. I want fast spooling as opposed to higher boost as I drive off road a lot and throttle response is very important. BTW if anyone needs a VNT 15 let me know. I paid $250 for it. Oh, I modified the actuator to work off boost, but it should be able to be changed back.
Reply #1March 04, 2007, 05:28:49 pm
Black Smokin' Diesel
  • 656
Crap, I'm screwed
« Reply #1 on: March 04, 2007, 05:28:49 pm »
Could use a thick spacer on the exhaust manifold so it clears the starter?
91 Passat syncro 1.8T swapped.
Reply #2March 04, 2007, 05:31:47 pm
SMOKEYDUB
  • 630
Crap, I'm screwed
« Reply #2 on: March 04, 2007, 05:31:47 pm »
i am with that idea and just heat sheild the crap out of the starter.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3March 04, 2007, 05:32:02 pm
scopefrfd
  • 289
Crap, I'm screwed
« Reply #3 on: March 04, 2007, 05:32:02 pm »
try flipping the exhaust manifold..you may have to clearance the tabs a little and clock the turbo..but it should work
Reply #4March 04, 2007, 05:32:12 pm
Crap, I'm screwed
« Reply #4 on: March 04, 2007, 05:32:12 pm »
Quote from: "Black Smokin' Diesel"
thats an awesome idea!!!
Reply #5March 04, 2007, 05:33:27 pm
vnt
« Reply #5 on: March 04, 2007, 05:33:27 pm »
Well, it would have to be close to 3-4". The thought crossed my mind. It could be a little thinner if I angled it, but it still would be a bit of work.
Reply #6March 04, 2007, 05:33:31 pm
itzdshtz
  • 94
Crap, I'm screwed
« Reply #6 on: March 04, 2007, 05:33:31 pm »
Do you have room in the Landrover to mount the manifold upside down and rotate the turbo cartridge so that your oil drain points down again?
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #7March 04, 2007, 05:36:24 pm
vnt
« Reply #7 on: March 04, 2007, 05:36:24 pm »
No, the turbo hits the intake.
Reply #8March 04, 2007, 05:37:39 pm
itzdshtz
  • 94
Crap, I'm screwed
« Reply #8 on: March 04, 2007, 05:37:39 pm »
Wow, 4 answers within 4 minutes! I see Scopefrfd had the same thought.
1997 Audi A6
1985 Audi 5000 Td
Reply #9March 04, 2007, 05:41:12 pm
Crap, I'm screwed
« Reply #9 on: March 04, 2007, 05:41:12 pm »
Does the vnt 17 or whatever it is called, have the same configuration?
Reply #10March 04, 2007, 05:41:43 pm
itzdshtz
  • 94
Crap, I'm screwed
« Reply #10 on: March 04, 2007, 05:41:43 pm »
Can you modify a golf diesel starter and mount it on the opposite side of where your starter fits now? It seems to have a cover on it.
1997 Audi A6
1985 Audi 5000 Td
Reply #11March 04, 2007, 05:43:56 pm
Crap, I'm screwed
« Reply #11 on: March 04, 2007, 05:43:56 pm »
Nope. I had to have a custom adapter made to fit the Rover tranny, and that is the only place the starter would fit. I do appreciate all the ideas though.
Reply #12March 04, 2007, 06:08:24 pm
VNT
« Reply #12 on: March 04, 2007, 06:08:24 pm »
Didn't see any there, and I don't do german very well, but it gave me the idea to search the UK. There might be some possibilities there. Thanks.
Reply #13March 04, 2007, 06:20:39 pm
scopefrfd
  • 289
Crap, I'm screwed
« Reply #13 on: March 04, 2007, 06:20:39 pm »
Shipping from the UK will kill you....the VNT 17, the early versions had seperate turbo housings, they're kinda pricey but very nice.  I still think you're best bet is to flip the manifold and buy a turbo flange that are sold for guys making they're own turbo log-type manifolds.  I think techtonics sells the flanges...and I believe they're 1/2" thick...may be enough to get by the intake.  Also, I think a 1z intake has a very small profile width wise.
Reply #14March 04, 2007, 06:34:16 pm
flange
« Reply #14 on: March 04, 2007, 06:34:16 pm »
Is ther a web site? All I can find are exhaust systems, but no flanges
