General Information
Troubleshooting
Jetta with no power
Topic: Jetta with no power (Read 4587 times)
February 26, 2007, 09:22:40 am
slajjs
Newbie
Jetta with no power
February 26, 2007, 09:22:40 am »
Started having problems with my 91 Jetta a couple weeks ago when the weather got really cold. It had been running great for over a month, then would barely start, smoke like crazy and had no power. The temp had gotten down to -2F or so for the night. Thought the fuel had gelled, put PS 911 in the tank and in a new filter. Still have the same problem. The motor has new rings and head gasket (less than 2k miles ago). Timing is right where it should be. Did I damage the pump? Anyone have any ideas? Thanks
February 27, 2007, 04:32:06 am
Jetta with no power
February 27, 2007, 04:32:06 am »
sounds like you need some diesel purge :wink:
February 27, 2007, 07:00:55 am
slajjs
Newbie
Jetta with no power
February 27, 2007, 07:00:55 am »
Thanks for the suggestion. Tried driving it last night, the outside temp was a little above freezing. It's running like it's not getting enough fuel. I'll try the purge and let you know.
February 27, 2007, 08:11:17 am
Jetta with no power
February 27, 2007, 08:11:17 am »
do you notice any bubbles in the lines while running??? if theres a lot of bubbles the purge won't do much...
February 28, 2007, 07:32:41 am
slajjs
Newbie
Jetta with no power
February 28, 2007, 07:32:41 am »
Just found a place that has LM Diesel Purge and will hopefully try to get it done tonight or tomorrow. I'll be sure to check the fuel lines beforehand.
March 04, 2007, 05:35:03 pm
slajjs
Newbie
Still smokin
March 04, 2007, 05:35:03 pm »
Ran the bottle of LM DP through yesterday. Seemed to be running a lot better. Idle returned to normal, most of the smoke had stopped. Hooked the fuel delivery back up and took it for a ride. Ran better but still had little power and started smoking again. Could the fuel be bad? It's down to 1/4 tank, has some kerosene and diesel 911 mixed in. I'll try getting some fresh fuel and run it through the pump to see if it runs better. Any other ideas? I'd appreciate any input. Thanks
March 04, 2007, 05:37:15 pm
Jetta with no power
March 04, 2007, 05:37:15 pm »
well i'm starting to wonder if you have the blocked filter screen... or a bad check valve??? hmmm i think it was veeman who ripped out the filter screen that sits in the tank..
March 05, 2007, 06:52:27 am
slajjs
Newbie
Jetta with no power
March 05, 2007, 06:52:27 am »
The blocked filter would make sense. Of course, it's going to be really cold here the next few days so I won't be working on any cars for a while. Do you know if there is an inspection plate that allows access to the fuel lines or do I have to drop the tank to get at them? Might be time to purge the whole system. Thanks for your input so far, you got me thinking in the right direction.
General Information
Troubleshooting
Jetta with no power
