Author Topic: Crank-shaft difference. Information needed.  (Read 5682 times)
February 22, 2007, 12:53:54 pm
subsonic
  • 1836
« on: February 22, 2007, 12:53:54 pm »
Could someone please point me to a link, or towards a website that shows the specs for a 1.7td crank.  I would like to compare it against the 1.6td crank specs.
Thanks, jim
Reply #1February 23, 2007, 05:35:50 am
Audi80
« Reply #1 on: February 23, 2007, 05:35:50 am »
1,7D and 1,6TD uses same crank
Reply #2February 23, 2007, 05:45:21 am
myke_w
  • 1099
« Reply #2 on: February 23, 2007, 05:45:21 am »
Same crank - same part #  068105101M
Reply #3February 23, 2007, 06:33:00 am
subsonic
  • 1836
My thanks.
« Reply #3 on: February 23, 2007, 06:33:00 am »
Thank you!  You guy's kick ass.
 :D
Reply #4February 23, 2007, 06:45:17 am
subsonic
  • 1836
So, if this is the same........
« Reply #4 on: February 23, 2007, 06:45:17 am »
Audi80, Myke_w, do you have any experience or knowledge of anyone converting a 1.6td to a 1.7td by going to the larger pistons?  You have confirmed that the crank is the same.  I believe that I have read here earlier that the piston pins are the same.  Would it also stand to reason that the rods are the same as well?
I am heading to Canada next week to pick up two 1.6td's.  Motors are already pulled, complete.  One I was told had the bad heat cracks between the valves.  The other should be solid.  I am also picking up a 1.9TD head.  It will need a rebuild.  I was told the camshaft BROKE :shock:  while it was running. It is still straight.  Looks like a good oppertunity for the Pass. Perf. camshaft upgrade.  Thanks again for the help.        Jim
