Turbo Boost
Topic: Turbo Boost (Read 3240 times)
February 08, 2007, 06:50:21 pm
not4sho
Newbie
Turbo Boost
February 08, 2007, 06:50:21 pm »
I have a 1990 Jetta TD engine in my 1992 Golf running 12 PSI. Just currious as to how to up the PSI and what is safe to run with factory fuel delivery, and stock engine. No P/S or A/C.
1994 Jetta 2.0L gas
February 08, 2007, 06:53:20 pm
Turbo Boost
February 08, 2007, 06:53:20 pm »
you can run as much boost as you want, the fueling is what will ultimately kill your engine. with factory fuel delivery you'll have a hard time getting passed around 15psi, you need more fuel to make more boost.
February 08, 2007, 07:14:00 pm
Turbo Boost
February 08, 2007, 07:14:00 pm »
The headgasket is another weak point to worry about
February 09, 2007, 04:38:27 am
not4sho
Newbie
Turbo Boost
February 09, 2007, 04:38:27 am »
what type of headgasket would you recomend to upgrade to and what injectors would you recomend to upgrade to?
1994 Jetta 2.0L gas
February 09, 2007, 05:08:31 am
g-spec
Turbo Boost
February 09, 2007, 05:08:31 am »
You dont "have" to get injectors...you could just get your rebuilt....
in order to increase fuel you can go to the thread on making your TD faster....its on the forum.
February 13, 2007, 05:11:15 am
not4sho
Newbie
Turbo Boost
February 13, 2007, 05:11:15 am »
I cant find the thread you are talking about. how do you adjust the wastegate to get higher boost? if you know where the thread is could you post a link to it?
1994 Jetta 2.0L gas
February 13, 2007, 05:34:57 am
1slowvw
Turbo Boost
February 13, 2007, 05:34:57 am »
The thread is in the FAQ section and is second from the top as i write this, It explains how to adjust your turbo's wast gate, as well as how to increase fueling, and some other little tricks.
1SlowVW
Turbo Boost
